Need HELP! Hotchkis springs...again.
Old Apr 15, 2007 | 11:05 PM
tCduck's Avatar
Default Need HELP! Hotchkis springs...again.
I have the springs off the struts and I can't get the new spring compressed enough to go back on. And this is on the rear struts. Any ideas about what to do?
Old Apr 15, 2007 | 11:19 PM
Mid_Life_tC-risis's Avatar
Gotta buy full coilovers now ....
Just kidding. Might have to take your assemblies to a shop and have them install the springs. Shouldn't cost that much for just two springs.
What are you using for spring compressors?
Old Apr 15, 2007 | 11:53 PM
Hat_Trick_Hokie's Avatar
I had the same problem. See if this helps... https://www.scionlife.com/forums/viewtopic.php?t=170067
Old Apr 16, 2007 | 12:53 AM
1slowtc's Avatar
Strictly Scionized
i went to the auto parts store some of them rent the tools out just need a spring compressor tool autozone is where i rented it cust 30 dollors the got it back when i took the tool back
Old Apr 16, 2007 | 01:54 AM
tCduck's Avatar
I have the tool, the problem is compressing it enough to get the top of the strut on.
As far as trying what the guys in the post did, I started to try it and I felt like it didnt want to hold and one of the tools started to slide off so I quit. Gonna take it to a shop tomarrow to have them put the springs on.
Old Apr 16, 2007 | 02:29 AM
Tcguy85's Avatar
put the assembly in the rear arm and jack the rear arm up and then put the nut on when the spring is compressed enough. i might not be explaining it very well. not sure how else to explain it.
Old Apr 16, 2007 | 03:45 AM
This would be a good thing to try before you take it to a shop. I heard its the easiest way to do the rears.
Old Apr 16, 2007 | 01:31 PM
tCduck's Avatar
Already talked to a guy that works at the dealership here. They are only gonna charge me so much. I just put the struts and springs in my van and Im going to drive up there have them put it on then finish it up today.
Old Apr 16, 2007 | 02:18 PM
^^Sounds good. Don't know if you're keeping stock shocks or bought aftermarket struts, but make sure they're lined up properly with the top spring seat or the assembly won't fit into the car. If they're stock shocks you should have already marked the shock and top seat before you took them apart.
If the tech isn't sure they're lined up right, just have him install the spring but keep the nut just loose enough to where you can bring then home and rotate the top seat into alignment where it will fit in the car. Then you can torque the nut to spec.
Old Apr 16, 2007 | 09:27 PM
hotwheelsrs1's Avatar
dude i just did mine yesterday with the rental spring compressors from kragen, what i did was compress the spring as much as u can, then put it on the strut, and set the top mount on in place, then i took 2 pieces ow wood of each side of the top plate and just pushed as hard as i could while a buddy of mine got the nut threaded a little bit then tightened it the rest the way with my impact gun, it sucked but it worked and i didnt have to pay anyone.
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
carid
Feb 12, 2015 11:54 AM
TheTripleC
Jan 4, 2015 06:46 PM
scionlife
124
Sep 30, 2004 09:02 PM
Wide_tC
Apr 14, 2004 07:39 PM
