Install LED Light in glove box
Old Apr 16, 2007 | 06:00 AM
Leganza's Avatar
Default Install LED Light in glove box
OK.. I was a little frustrated because of automatic on/off for trunk light..
So my next target was glove box cause there's no light in there originally~ hee hee hee...
I put a same switch on it, so it's gonna get on when glove box opened and off when closed.
As usual ^^, PCB with LEDs....
and light cover...
removed metal terminals to install PCB inside..
switch...
Test before installation in the car
Installation...
wiring...
Now I can see anything inside of glove box at night....
sweeeeeeet~~! ^^
Old Apr 16, 2007 | 06:19 AM
O5_TRD_tC's Avatar
nice where did u get the light housing from?
Old Apr 16, 2007 | 06:28 AM
Leganza's Avatar
I bought it from other country before I left the country and I brought it here when I moved. It was about 10 bucks and included housing, bulb, switch, wires and some connectors. I actually tried to find similar stuffs at ebay, but couldn't find anything.
Old Apr 16, 2007 | 06:48 AM
SquallLHeart's Avatar
now there's a mod that you can be proud of..
dude man... we gotta met up and grab lunch sometime!
Old Apr 16, 2007 | 06:59 AM
KINGxOFxSKA's Avatar
Unique Scionikz
*jealous*
Old Apr 16, 2007 | 07:03 AM
Leganza's Avatar
Thanks for your compliment!!
Old Apr 16, 2007 | 03:05 PM
jetlounge's Avatar
I don't understand..you say its only on when the box is opened, but you also have a toggle switch.
Did you wire a pressure sensor to the glovebox so it only comes on when the glovebox is opened?
Old Apr 16, 2007 | 03:54 PM
rhino74s's Avatar
Very cool mod!
I mounted the 2 cupholder led's ,that come with the stock lighting kit, in my glovebox. Obviously it doesn't put out that kind of light but it's better than nothing.
Old Apr 16, 2007 | 04:28 PM
FIREDOG's Avatar
its not a toggle switch look closely at the picture...
Old Apr 16, 2007 | 07:27 PM
jetlounge's Avatar
the images are so tiny.
is it a pressure switch next to the tire pressure reset?
if that's it ok, i get it. i wouldn't have put it there though.
Old Apr 16, 2007 | 07:34 PM
Leganza's Avatar
Yes it is a kind of pressure switch. It goes on when swith released and it disconnects two wires when switch is pressed in. It just works backward compared to normal switch.
Old Apr 16, 2007 | 09:38 PM
Unique Scionikz
make the pics bigger.
Old Apr 16, 2007 | 11:28 PM
all4degame's Avatar
looks very good!
Old Apr 17, 2007 | 02:13 AM
Leganza's Avatar
I post one big picture of switch in the thread now.
So many scratches..... -.-+
Old Apr 17, 2007 | 03:04 AM
rvpps2rocks's Avatar
this is something i definatley gotta do because i can never see in my glove box...do u mind writing a DIY or telling me what parts you used
Old Apr 17, 2007 | 03:11 AM
b_adair87's Avatar
Im sure you could go to the junkyard and get the housing from another car and just wire it all up right. Nice install
Old Apr 17, 2007 | 04:40 AM
Leganza's Avatar
I'm sorry I actually don't know where you can buy it in the US. I bought it from my home country. I only searched similar housing and switch on ebay, but nothing's there. Anyway I'm planning to register "sponsored sales" in this site soon and then I probably can provide it to you guys.... Anyway..
Let me try to explain it more detail about a wiring.
You see the red(+) and black(-) wires in the above picture. One of the wires(I recommend "black") need to be connected with switch, so bring black wire to the switch, and then cut wire and strip both ends, then hook up both balck wires with two terminals of switch respectively.
This switch is designed to connect both black wires when glove box door is opened(switch released). when glove box cover(door) presses the switch down, it disconnects both black wires.
Now when you've done with the above, bring red wire(from housing) and black wire(from switch) to near the floor on passenger side. See the below picture.
As you see the picture above, I hook those black/red wires up with wires of scion's interior mood light. It consists of black(-) and blue(+), and splice black-black and red-blue by using below picture.
I didn't have above splice connectors, so I just used a different connectors.
now everything's done, so just arrange wires, put some tape not to cause any noise. That's about it. Just let me know when you get any trouble during your mods. ^^
jaspercanda
Scion tC 2G Aero & Exterior
14
Feb 3, 2020 02:43 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
ScottsXBScion
Nov 25, 2003 10:30 PM
sithscripter
9
Sep 26, 2003 05:27 AM
