Tap straight into battery for LED switch?
Old Apr 16, 2007 | 03:38 PM
midtowndesi's Avatar
Default Tap straight into battery for LED switch?
I recently installed cold cathodes and an Oznium lit LED switch into my xB. instead of using the fuse box to get a "constant 12v" power, i tapped straight into the battery (+ terminal)and put a 10amp fuse in that line.
my question is - is this okay? i'm not draining the battery or anything am i? or should i rewire this through the fuse box?
this is a diagram of what i did. my cathodes work fine and my car has started fine for the last 2 weeks after the install - so i dont think it's draining the battery or anything like that.
i just wanted confirmation to make myself feel better. does this look okay? any glaring mistakes i've made?
thank you guys in advance!
- sh00k
Old Apr 16, 2007 | 05:04 PM
jallamas's Avatar
There should be no problem with that, I would find out how much the lights draw (amps) and get a fuse closer to that range of the light. 10 amps seems a lot for cold cathodes.
John
Old Apr 16, 2007 | 05:45 PM
Thank you for the reply john! I read somewhere that the amp useage per cathode set is 3 amps. i only have the 1 set put in right now but will be adding 2 more sets for a total of 3. so it'll be drawing 9 amps with a 10 amp fuse in!
i appreciate your input! thank you for your reply,
- sh00k
Old Apr 16, 2007 | 05:57 PM
jallamas's Avatar
Cool! Your welcome!
Old Apr 17, 2007 | 03:46 PM
Oops - I was wrong before. 1 set of Oznium cathodes only draws .7 amps of 12v power. therefore, I will replace the 10 amp fuse that i have with a 3-5 amp one.
- sh00k
Old Apr 17, 2007 | 05:09 PM
jallamas's Avatar
That sounds a whole lot better, always remember keep the fuse rating close to the accessory rating.
John
LzeroKI
Apr 1, 2015 06:44 PM
CPL_Radar
Mar 5, 2015 05:42 AM
tc_Jake
Dec 31, 2014 01:45 AM
fliggah
Dec 25, 2003 01:03 PM
