system help...
Old Apr 16, 2007 | 09:57 PM
willingwelli's Avatar
Default system help...
i need to some help figuring out what to do. right now i have my headunit powering my speakers, but i want to change that around... i want my 2 front speakers to run off my amp but the back speakers to powered by my headunit... which wires would I need to change behind the cd player to do this? I have an eclipse cd3100... thanks.
Old Apr 16, 2007 | 10:11 PM
Daskid's Avatar
This is what would I do:
Headunit > RCA cable > 2ch Amp > Front Speakers
Just cut off the connection coming from the headunit to the front speakers and leave the rear speakers alone. Then connect the Amp's speaker output to the front speakers. And you're all set!
Old Apr 16, 2007 | 10:17 PM
alright, thanks... but you could explain that to me a little easier? I'm still kind of noob at this.
Old Apr 16, 2007 | 10:29 PM
rhino74s's Avatar
Stock headunit or aftermarket?
If stock you will need an adapter to give you rca connections.
If aftermarket just plug the rca cables in and run new speaker wire to the doors.
Old Apr 16, 2007 | 10:48 PM
Daskid's Avatar
Actually you can just use the wires you cut off of the radio. It is still going to the front speakers. Just run wires from your amp back to your headunit and connect it to the wire you cut going to the speakers.
I would suggest mounting the amp underneath the passenger seat.
Just visualize and use your imagination. You can do this!
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
yhwhdesign
Jun 11, 2021 03:34 PM
Hydryman
Feb 23, 2016 03:35 PM
brett561tc
Sep 15, 2015 06:33 AM
Subaru86
Jul 31, 2015 04:33 AM
