View Full Version : Sway Bar Install (Rear, Progress)
GammaTNT 04-18-2007, 08:00 AM I got Progress rear sway bar from http://www.newedgeperformance.com/index.asp?PageAction=VIEWPROD&ProdID=414
tools i use is
14mm socket and
two 14mm Ratchet Wrench.
hex key tool ( 3/16)
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/tools.jpg
Jack up the car with Hand brake on. I removed the rear passenger's tire. it made it easy to slide the sway bar out.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/carjack.jpg
Now remove the those 4 bolts from under the car.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/bar1.jpg
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/bar2.jpg
now removing the Endlinks, just the lower nut needs to be remove, You can leave the nut connected to sway bar alone
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/Endlink1.jpg
You need the Hex Key to keep it from turning while removing this nut.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/Endlink3.jpg
Now slide the bar toward the passenage side where the wheel was removed.
Comparing the Progress Bar and the stock bar. Progress Bar weight almost twice as the stock bar.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/swaybarcompare.jpg
Now slide the new bar in.
Cut open the grease tube that come with Progress Bar and grease up the inside of the new bushing.
Put on the new bushing and new brackets. Then tighten the bolts and nuts.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/newswaybarin.jpg
I use the two Ratchet Wrenches to tight the new endlinks.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/newendlink.jpg
Passenger side rear view
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/Endlink5.jpg
Driver side rear view
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/Endlink4.jpg
I used the inner hole for firmest setting.
http://i11.photobucket.com/albums/a156/gammatnt/car%20stuff2/Endlink6.jpg
Recheck and re_tighten everything.
ricexizxgood 04-18-2007, 08:10 AM Nice Write up
kikcaffine 04-19-2007, 05:44 AM What do the new end links do? And why is your car SOOOO rusty already?
Neothin 04-19-2007, 05:51 AM new jersey = snow = salt = rust
good write up :)
GammaTNT 04-19-2007, 06:12 AM i didn't even pay attention to the rust, I though all cars' bottom rust like that. Luck my area don't get much snow or flood.
The Endlink just connect the bar to the car's body. Progress Sway Bar comes with new Endlinks.
I only tested the car in a school's parking lot. Much less body roll. The car feels more solid. HR coilover will be my next mod.
Bozuzu 04-21-2007, 06:13 AM I just installed the rear hotchkis bar and for the life of me can't get the two top bushing bracket bolts to thread back in the holes. Everything else lined up fine and it only took 20 minutes. Hotchkis provided 8mm allen head bolts for clearance, threads area identical to the stock bolts, why won't they take?
Otocan 04-21-2007, 07:53 AM I just installed the rear hotchkis bar and for the life of me can't get the two top bushing bracket bolts to thread back in the holes. Everything else lined up fine and it only took 20 minutes. Hotchkis provided 8mm allen head bolts for clearance, threads area identical to the stock bolts, why won't they take?
place a jack under the opposite wheel hub(rotor) on the other side of the car and jack it up an inch or two, the bolt is just a tad away from alignment, it's not an issue at all, the suspension just needs to be compressed a little bit to give you more space to use with the sway bar.
Blue_TC_Man 01-06-2008, 04:22 AM so now that you have had it for awhile how you like it? i just put mine on today
GammaTNT 01-06-2008, 06:29 AM first few week feel big difference. but now i got so used to it. I need to drive a stock tc again to really to feel the difference.
Chrisb319 01-06-2008, 07:04 AM Why did you pick the progress over the TRD? And are those the Dezod endlinks?
Aroddalobster 01-06-2008, 07:15 AM progress come with its own endlinks, and progress is has more adjustment settings than the trd. both from the same company anyway.
Chrisb319 01-06-2008, 07:17 AM It all comes together now. Thank;s for the clarification.
Great DIY. One thing to add to the "To do list" when summer decides to roll around.
AcidDrop 01-06-2008, 07:39 AM yeah same question as to why not the TRD, also seems alot better get cause you don't have to spent more on getting new endlinks.
Blue_TC_Man 01-06-2008, 05:48 PM first few week feel big difference. but now i got so used to it. I need to drive a stock tc again to really to feel the difference.
thats understandable, so far i love mine i hated feeling like i was in an suv on a tight turn
hawgs74 01-27-2008, 03:41 PM I never knew the progress came with new endlinks. Nice to know for future.
BuckeyeBrad 01-31-2008, 05:04 AM good DIY i think i might just have to get me one now ha
ExpresScion 02-01-2008, 02:16 AM Cool write up. My buddy and I just did my TRD sway last weekend. Waiting for my Dezod end links to come in the mail.
CSOCSO 02-01-2008, 02:53 AM no front? only rear?
Aroddalobster 02-01-2008, 03:12 AM nope. progress, trd only make rear sways.
azureloki 02-01-2008, 03:13 AM no front? only rear?
hotchkis makes front and rear sway bars
azureloki 02-01-2008, 03:14 AM nope. progress, trd only make rear sways.
there are others like hotchkis... i dont knot of the others bbut im pretty sure there are maybe not
Aroddalobster 02-01-2008, 03:18 AM i'm aware. i'm just saying that trd/progress only make the rears. same thing i guess..
Hyghgynx 02-01-2008, 03:24 AM Found this quote on the site...
"Progress has designed this rear sway bar kit to work in conjunction with the stock front sway bar to improve handling by getting the car to rotate more in the corners."
Does this make sense to anyone? I'm a bit confused. I was set on purchasing the Hotchkis Front and Rear Sway combo, but now I'm confused again. I might just purchase the Progress Rear Sway. I doubt I will ever need/use the front sway. HELP! :P
BTW; nice write-up! :clap: Will definitely come in handy whenever I do my install.
Aroddalobster 02-01-2008, 03:50 AM rotate more... as in oversteer? woo!
austinguy83 05-16-2008, 05:21 PM rotate more... as in oversteer? woo!
more like, as in not understeer as much.
cmv138 05-21-2008, 06:18 AM pretty cool that they come with the end links. im assuming that you just set it to the same length as the stock ones and lock it up with the nuts?
good DIY! thanks!
GammaTNT 05-22-2008, 03:12 PM i don't remember checking the length.
I just bolt every piece together.
Maybe i should take it apart and check it again.
TylerC08 03-18-2009, 03:11 AM errrrr bumpage but im just wondering how its held up for you.
just got it today and didn't find the grease so ima have to find a substitute, I'm assuming any silicone based lubricant will be okay....?
huslindan 03-18-2009, 03:23 AM so imma about to instail mine tomorrow... did you have to get your car re alignned after this instail? cuz if so i dont have 80 bucks to drop on a alignment right now?
huslindan 03-18-2009, 03:24 AM oh and you spend 189 ? i got mine from p tuning last week when is was free shipping and only 165 :)
TylerC08 03-18-2009, 03:26 AM so imma about to instail mine tomorrow... did you have to get your car re alignned after this instail? cuz if so i dont have 80 bucks to drop on a alignment right now?
No
huslindan 03-18-2009, 03:28 AM and riding stock height is ok with the stiffest setting ? progressive says to get a alignment im read it somewhere
TylerC08 03-18-2009, 03:35 AM hmmmmm. not sure.
thread awhile back claimed it wasn't necessary, now if you do a front sway then yeah, an alignment will be needed.
Mouse 03-18-2009, 03:48 AM nope. progress, trd only make rear sways.
I am running both the front and rear hotchkis sways... I did the install myself b/c I had the use of a bay at my local toyota/scion dealer (I have the inside track w/ them) and the use of a nice lift.
The reason that a lot of people dont install a front sway is that on the tC you have to literally drop the entire front sub-frame of the car in order to install it. Takes a few hours with the right tools and know-how. I will say this... having both of the hotchkis sways on...she corners like she's on rails! then I also have the TRD front strut tower brace...and dropped on hotchkis springs... handles so much better its not even funny. The hotchkis sways are wider diameter than most...and nice and stiff...
Anyone that rides in a tC like mine with the hotchkis TVS suspension setup... will be willing to fork over the extra cash to install the front sway if they cant do it themselves.
jsingh 03-18-2009, 03:49 AM nice diy!
thanks...i hope to get these or hotchkis soon!
Mouse 03-18-2009, 03:51 AM jsingh.... ^^ dude... if you cant do it yourself... fork over the cash to have the front hotchkis sway installed... you wont be able to wipe the smile off your face after experiencing the handling..... ***just a note***..... if you go with Hotchkis sways.... they are NOT designed to work if you only install the rear...as they are very heavy-duty stiff sways...
TylerC08 03-18-2009, 06:48 PM ^^^^Have you driven in a tC with just the rear progress sway/endlinks installed?
Mouse 03-18-2009, 06:53 PM No I have not...I know the Progress and TRD rear sways were designed to work just as is without a front sway. I'm just saying that running a setup with a front sway as well as the braces...is very tight...and handles very well. But also I was stating that the Hothckis brand sways are not designed to just install the rear sway.
I have ridden in my friend's tC and he just has the TRD rear sway on TRD springs... it definately handles better than stock..but not quite as tight as having the front sway and upper tower brace.
Mouse 03-18-2009, 06:55 PM I would put it like this....IMO
Stock= good
Rear sway + lowering springs = better
front & rear sway + lowering springs + strut tower braces = best
Aroddalobster 03-18-2009, 07:42 PM f&r sway + COILOVERS = bestest
its overkill for most, but nothing much can beat that
TylerC08 03-18-2009, 07:43 PM Understandable....
I just want to get this bastard installed asap...just laying there in mah garage seducing me. lul
Mouse 03-18-2009, 07:44 PM f&r sway + COILOVERS = bestest
Okay bucko...I'll give ya that on the coilovers....they are nice...and if I had that kind of change layin around I would probably be rolling on them.
Aroddalobster 03-18-2009, 07:46 PM :D
Mouse 03-18-2009, 07:50 PM well you had me on that one...I was thinking of my setup not the coilovers I wish I had...lol....but I admit when I've overlooked something lol... I think if a person cant eat a slice of humble pie....they shouldnt be dishing it out either lol
huslindan 03-18-2009, 08:41 PM yeah i cant afford coilovers either..lol imma just wait till i need to get new struts...
but what about this set up..
DME front and rear strut bar
progressive rear sway
integra c pillar bar
and H&R sport springs
ill be instailing all this week expect for the springs will that be stiff just as stiff???
Aroddalobster 03-19-2009, 01:45 AM i'd save my money and do the springs and progress sway. the rest you can do, but i'd put my money into something more useful like tires
huslindan 03-19-2009, 01:46 AM i have tires already lol i got rims and tires
TylerC08 03-20-2009, 11:49 PM So yeah this was definitely worth the money. Back end is tight as hell.
Good write up. helped me out quite a bit.
Mouse 03-21-2009, 12:07 AM errrrr bumpage but im just wondering how its held up for you.
I would think that a silicone based grease would be okay and not degrade the bushings. For some reason I thought I heard there was a lithium based grease for certain ones... but you might want to check with the manufacturer before you do it.
ahatch133 03-21-2009, 12:10 AM can u really feel that much of a difference?
Mouse 03-21-2009, 12:12 AM yeah i cant afford coilovers either..lol imma just wait till i need to get new struts...
sounds decent... you will notice a diff. up front with that tower brace...
I havent found a whole lot on the C-pillar brace... as far as how effective it is for the amount they cost. I think if I heard correctly that it attaches via the upper mounting points fro the rear seatbelts.
hell...I had even thought of installing a full 5-6pt cage until I saw the end result of a tC that had flipped 7 times on the highway and the roof didnt cave in one bit. So the factory frame is like it has its own built in roll cage... sweeeeet.....
Mouse 03-21-2009, 12:12 AM can u really feel that much of a difference?
with what exactly?
ahatch133 03-21-2009, 12:16 AM the difference between driving a stock one and a aftermarket one? being tighter?
Mouse 03-21-2009, 12:20 AM ^^ hatch... as far as aftermarket for front and rear sways, tower braces, lowering springs....yeah... it's a huge difference over stock... very worth the money for those mods. Mine handles like its on rails and very very little "roll" factor in cornering. If you drive a stock tC and then drive one that has its suspension modded like mine...its like night and day difference.
TylerC08 03-21-2009, 01:57 AM errrrr bumpage but im just wondering how its held up for you.
I didn't realize how small the tube was and just over looked it. But yeah shes all in and lubed up tight.....lulz..anyways
yeah its a great difference...im really wanting to get some dezod end links for the front now. but that will probably come way down the road.
itsharis 08-25-2009, 01:38 PM Great write up. I just installed my Progress (stiffest setting) and even though I have read that the difference should be really noticeable, I was still shocked to feel it. The back end was nice and tight in corners and if you really yank the wheel the car actually feels like its almost oversteering a bit and just keeps sliding. Almost no roll.
Really excited. I think if you are going to mod just one thing on this car, this should be it.
Can't wait to get a suspension upgrade and some better tires.
liltofuboix 09-02-2009, 09:24 AM good job
rangerryda 09-02-2009, 04:45 PM Rocking the Hotchkis F+R sways at tightest setting, TRD springs, DC Sports front tower brace, and 8.5" wide rims with pirelli's. Handles on rails. Front sway is a bear though. Took me about 2 hours to do with a lift and all the right tools.
Shaolin_Style 09-30-2009, 01:26 AM i just saw an RSX with the progress rear and it had a cool little label thing on it why does'nt yours??
rippintC 09-30-2009, 03:09 AM well i'm gunna throw this out there...i'm on hks coilovers, hotchkis f&r sways, trd strut bar and worn out toyo proxes4. it feels very unstable and rides like rock. body roll is minimal if i can get it turn in the first place lol. simply put, i can't stand it! i'm considering getting new tires asap, going to just progress rear sway and some hothckis lowering springs. 1 finger gap up front, 1.5 rear.
wat is the diff between inner hole and outter hole ??
is it gonna effect car performance ?
DJ08tC 10-08-2009, 02:07 AM Yea, the inner hole will make it a lot stiffer so it will handle better, there will be less body roll.
good info, does anyone have advice on the best place to get hotchkins sways?
CSOCSO 10-31-2009, 08:28 PM hopupracing.com
or
http://www.corsportusa.com/store/catalog/product_info.php?products_id=1063
or
http://www.dezod.com/pd_progress_rear_sway_barscion.cfm
theyre all the same thing right ? all come w/ new endlinks ??
GammaTNT 11-04-2009, 04:53 AM i believe they are all the same. but only Newedgeracing post the correct picture. The other 2 dealers didn't bother to take time to post the correct picture.
I got mine from Newedgeracing.
GammaTNT 11-04-2009, 04:54 AM plus it come with new endlinks
Chrisb319 11-04-2009, 06:44 AM well i'm gunna throw this out there...i'm on hks coilovers, hotchkis f&r sways, trd strut bar and worn out toyo proxes4. it feels very unstable and rides like rock. body roll is minimal if i can get it turn in the first place lol. simply put, i can't stand it! i'm considering getting new tires asap, going to just progress rear sway and some hothckis lowering springs. 1 finger gap up front, 1.5 rear.
I have Tokico HP blues,hotchkis springs and F&R sways, ingals rear brace, DC sports front tower bar. rolling on Enkei RPF1's 17x8 and Falken 452's, and the ride is amazing! The sway bars made a HUGE difference I feel like I have much more controll over the car.
As for the progress bar, if I did not get an awesome deal on my F&R bar set I would have most likely bought a progress bar. It's the best rear bar you can get for the tC, good set up for a DD.
hey what do we know...I guess the 25MM progress bar is the way to go :)
