Engine Cover Paint!!! Brand, Durability...
Old Apr 18, 2007 | 08:28 PM
SPscionTC's Avatar
Default Engine Cover Paint!!! Brand, Durability...
Ok i'm looking to paint my engine cover, (and i went to Kragen Auto and i saw some engine spray paint but i wasn't to sure about it) and I've looked around SL for awhile now, and i don't see any stright forward Forum on this so if anyone could help me get started please don't hesitate to post, also if you find a link to anything please help...
I was wondering what all of you fellow Scion owners used to paint your engine covers? Such as brand of the paint, and where you bought it, and how much?
Also if it was/is durable, such as any problem or set-back that it cause? (If any)
p.s.
anything will help me get started.
Thank You!!!
Old Apr 26, 2007 | 12:55 PM
Utownmatt22's Avatar
I second his statement. I've spent all morning on here and can't find anything on a brand or specific type. I don't wanna paint it and then two days later the paint chip off or crack under the heat of the engine bay.
Old Apr 26, 2007 | 04:17 PM
gizmokat's Avatar
the plastic cover is a little bit flexible so some people recommend a "flexible" paint I forget what it's called.
Personally i've used Duplicolor Metalcast and it worked out great. Any of the high heat engine paints should be fine. Duplicolor makes a bunch of different colors. Just make sure to follow the general painting steps (sand, primer, sand, primer, sand, paint, etc...) and you should be fine. If you want to make sure the paint sticks to the plastic well, either rough it up with sandpaper or you can use adhesion promoter.
Old Apr 26, 2007 | 05:44 PM
Or you could get the Krylon plastic paint. It's kinda meant to get hot since it can be used outside on lawn furniture. I just painted my engine cover on my lunch hour with that paint and it looks great. Plus there's no prep for that stuff. Since it's going on a plastic surface you just point and shoot, but make sure to do light coats, and yes it will take about 15 coats.
Old Apr 26, 2007 | 05:48 PM
2_much_tc's Avatar
i got mine powdercoated BSP and it looks great.
Old Apr 26, 2007 | 06:10 PM
TheQuietThings's Avatar
How do you powdercoat something thats plastic?!
Old Apr 26, 2007 | 06:16 PM
chrisP's Avatar
:watching:
Old Apr 26, 2007 | 08:01 PM
gizmokat's Avatar
I've been wondering that myself.
As far as durability
I have the Duplicolor Metalcast in purple on my Matrix engine cover, it's been 2 years and seen 2 salty NY winters and still looks great
Old Apr 26, 2007 | 08:03 PM
For anyone looking to keep their engine cover immaculate.
Buy a 2nd cover, and keep the nicely painted covered off the car unless at shows/meets lol.
Old Apr 26, 2007 | 08:12 PM
xSTANDxSTRONGx's Avatar
Team XcelsiA
^^ good tip, and
aka watching.
Old Apr 26, 2007 | 09:51 PM
2_much_tc's Avatar
well, i didnt powdercoat it myself. i took it someone to get powdercoated. he painted it BSP. I will post a pic when i get home.
Old Apr 26, 2007 | 09:53 PM
ok, well there is a HUGE different between powdercoating and painting. FYI anything that is plastic cannot be powdercoated.
Old Apr 26, 2007 | 10:03 PM
gizmokat's Avatar
Haha Watching what?
^from the Matrix, not sure I want to do the same to my TC
Metalcast is made to withstand up to 500 degrees.
http://www.duplicolor.com/products/metalcast.html
The Duplicolor Engine Enamel also goes up to 500 degrees
http://www.duplicolor.com/products/engine.html
you can watch their demo in the learning area, lolz.
I'm using a combination of both for my calipers.
You just need to take your time with painting to make sure it doesn't bubble/crack. prep well, sand good, wait between coats, and don't be impatient. now if only I could take my own advice, LOL.
Old Apr 26, 2007 | 10:07 PM
Frosty355's Avatar
https://www.scionlife.com/forums/vie...ne+cover+paint
Old Apr 27, 2007 | 02:47 AM
gizmokat's Avatar
^ werd
Also if you want the lettering, after you paint the cover in a different color. Ycart has vinyl stickers.
http://importequipment.com/catalog/c...roducts_id=125
Old Apr 27, 2007 | 07:33 PM
Team XcelsiA
^^You can also use that vinyl for a mask...Paint the lettering, let it dry, put the vinyl on, paint over it all, take off the vinyl, clear it
Old Jul 12, 2007 | 04:13 PM
STNC's Avatar
Where do you get the clear coat from?
LostCause
Scion tC 2G Aero & Exterior
33
Jul 9, 2015 09:00 AM
eric_m
79
Mar 17, 2013 12:21 AM
2fixA
33
Jul 30, 2004 03:13 AM
Besk_one
Nov 17, 2003 09:28 PM
