Oznium HID kit help!!!!
I know this question had been asked, because I have seen the responces to it. I just can not seem to find the answers when I need them. Ok, I need some help. I got this HID kit from Oznium, went with the 8000k 9006 kit, and I tried putting it in and turned it on and nothing happened. I'm asuming the problems lies on the user end (my self) So here is a pic of what I have, and what it looks like the wires are for.
The blue, I have no idea what it's for, because niether end lead to the light, or the ballast
The yellow pluggs into my current harnis
The greens plug into each other
is that right?
Also, once some one can tell me how to plug the dag gone things in right, where have everyone else mounted their ballasts?
is that right?
Okay, blue is for power and ground, greens plug into each other, yellow into your harness. Ballasts, use 3m tape and mount on the side walls of the engine bay, works like a charm. If I'm not mistaken, you can add the power to your battery and ground it somewhere with exposed metal in the engine bay, or where your intake is mounted, near there is a screw towards the CA extension under the mud guard where your filter would be. Hope that helps!
Cable #1 plugs into stock headlight harness.
Cable # 3 (blue wire) connects to the red wire that goes directly to the bulb.
Cable #2 and the small black wire can be pulled out through the grommet and not used.
Those were directions that Oznium gave me when I had the same question.
Been running them for around 6 months now with no problems.
ok i have the same exact kit, if you look where #1 is in the last pic.
I had to switch the red and the black wires in order to get mine to work.
so try it first (with the way it is wired) then switch the connections if it doesn't work.
As for #2 you dont need at all. just put it away.
Make sure you test it before you plug it into your housings
is it to late to add these projectors to my project and just use my current HID's?
I guess i didn't really think about these until now
http://jlevistreetwerks.com/store/p4...42ff4dad6a1ebb
Welp that's that, all done. I ended up having to chop of the connecter that attaches to the harness and reverse the black and red wires like stated above. I mounted the ballast on the drivers side to the wall beside the air intake, and the passenger side one face down attached to the frame beside the windshield washer fluid shaft. Looks awsome, and works great. Got some engine bay light in while I was messing around in there (2 4.7inch LED strips on each side, and one 36 inch under the radiator shining up)
S7ephavs
Mar 22, 2015 12:09 PM
umnitza
Dec 1, 2014 06:26 PM
