noobie ground wire connection.
Old Apr 21, 2007 | 01:37 AM
gicode0823's Avatar
Default noobie ground wire connection.
for your amp ... where did you get the ground wire from ?
thanx
Old Apr 21, 2007 | 01:38 AM
nytlemgr's Avatar
Do you mean, where can you purchase the wire?
Old Apr 21, 2007 | 01:39 AM
ricexizxgood's Avatar
Default Re: noobie ground wire connection.
thanx
Any part of the chassis, just make sure you scrape off the paint and you'll be fine.
Old Apr 21, 2007 | 01:41 AM
gicode0823's Avatar
where did you put ur ground wire ? i dont have any idea where to put it ...
Old Apr 21, 2007 | 01:43 AM
nytlemgr's Avatar
rear seat belt bolt, under bottom part of seat. works in every car i've owed.
Old Apr 21, 2007 | 01:46 AM
gicode0823's Avatar
do you have to take seat out to putit?
Old Apr 21, 2007 | 01:49 AM
nytlemgr's Avatar
yes.
jallamas's Avatar
Old Apr 21, 2007 | 01:50 AM
gicode0823's Avatar
how do u do that
Old Apr 21, 2007 | 01:58 AM
jallamas's Avatar
What we need to know is are you talking about installing the amp and where to ground it? If that the case it would be advisable to remove the seat to mount the amp. Make sure if there is any to un-plug on the TC seat to do so. It should only be four bolts and then take out the seat. Make sure when you drill through the floor board you do not hit any electrical; or agas lines or the such. Use one of the seat bolts as your ground and make sure there is metal contact foe the ground to be proper.
John
Old Apr 21, 2007 | 01:59 AM
nytlemgr's Avatar
took some searching but this should help you...
https://www.scionlife.com/forums/viewtopic.php?t=60981
Old Apr 21, 2007 | 02:00 AM
jallamas's Avatar
^ perfect!
Old Apr 21, 2007 | 02:02 AM
nytlemgr's Avatar
Originally Posted by jallamas
^ perfect!
:D Thanks!! It felt like I was searching forever, thinking I know it's here somewhere!!
Old Apr 21, 2007 | 05:06 AM
gicode0823's Avatar
is this bolt will work for ground ?
Old Apr 21, 2007 | 06:07 AM
KINGxOFxSKA's Avatar
Unique Scionikz
this guy and his questions again...
Old Apr 21, 2007 | 10:08 AM
SquallLHeart's Avatar
anything metal connected to the chassis is a ground...
Old Apr 23, 2007 | 08:01 AM
Ty_Max's Avatar
I used my strut as a ground ...but that isn't recommended most likely but it is a heck of a ground.
Nerdcore314
May 1, 2015 11:54 PM
randode
44
Jun 29, 2004 04:19 PM
pmpnxb
11
Jan 27, 2004 04:36 AM
bryanrx7
Jan 1, 2004 09:53 PM
deathcabforme
Oct 16, 2003 04:02 AM
