Oil Light
Hi, I changed my oil 2 days ago by myself with 5w-20 Mobil1 synthetic and a Mobil1 filter. I used 4 quarts of oil as instructed and I made sure everything was tightened when I finished.
The problem is every now and then, the red oil light will come on. I checked the oil level and it's full, but I have to admit it's hard to see because the oil so clean and clear...but anyways, are there any reason why the light is going on and off? It's off more than it is on, but it worries me.
Thanks.
Thanks.
Yeah, but I swear on the forum somewhere, somebody said 5w-20 was recommended for 06+.
The dealer is a good idea, I'll definitely see what they can do, if they don't charge me.
toyota tsb reccomends 5w20 for '06+
it was a change made after it came out.
there's no major difference between 5w30 and 5w20.. and for sure it won't do anything with regards to any sensor.
Originally Posted by boostaddict
easy solution what does the oil cap say??? 5-30 thats what goes in...it could just be because those cars are so sensitive to everything the oil is just teasing the sensor...
Read and learn.
yeah.. i'm still like.. car... sensitive.... teasing sensor?
words that i'm sure a well informed person in the mechanics industry knows with regards to this vehicle..
What does your oil cap say? If it says 5W30 then use 5W30, if it says 5W20 then use 5W20. If for any reason your oil cap doesn't say then look in your owners manual. 05-06 tC's take 5W30, Late 06-up take 5W20. And yes the weight of the oil can effect that sensor.
yes the cap says 5w-30, then toyota changed its mind to 5w-20
either will not kill your warranty, and will not harm the engine
Originally Posted by SSQ
did you remember to reset the oil change reminder?
I know, you probably did, but hey, just incase.
But I took it to the dealer and they found no problems. Even since then, the oil light is fine...so I guess it's fixed.
Thanks for everybody's help.
^^ yes.. the only thing that you would reset is the maint. req'd light and that would be the only thing as a reminder.
the acutal low pressure light which is red is not something you should want to see.... pretty much means.. you got no oil.. you're about to break your engine type of deal.
I checked up with a nieghbor of mines, he works as a techanician for Toyota. He confirmed that the 06+ should use 5W-20. Since you are mentioning about oil. I just checked my oil lvl it's below the halfway mark for some reason. I really need to change all my fluids on my car since it's all a dirty dirty color... (actually oil is fine colorwise)... my tranny and power steering fluids. They are all black ><. I need to flush them out ASAP.
if the 2AZ-FE is that sensitive, then toyota needs to rethink this engine design
