Amp Remote Blue Wire?
Old Apr 21, 2007 | 07:37 PM
ARIZONA-TC's Avatar
Default Amp Remote Blue Wire?
OK. I have the stock HU and I have everything done besides my Amp Remote Wire and I've searched and some people say Gray wire,
some say Blue but it seems like more agree with the Blue wire. Now I went and looked at the big harness and it has two Blue wires
Does anyone have a picture of which Blue wiring or which wire in general I need to tap for my Amp Remote?
__________________
Old Apr 21, 2007 | 08:47 PM
streetfire2006's Avatar
Deff use the gray wire, I have put a multimeter on both blue wires and the gray wire and the gray wire is the one to use. Thats how I have my tapped and a few others on SL are the same way. so I hope this helps you out!
Old Apr 21, 2007 | 09:24 PM
sddykstr's Avatar
It just needs to be tapped into any constant on source for power.
Old Apr 22, 2007 | 02:01 AM
Scionizer07's Avatar
^^^No, you are wrong. ^^^
You don't want to tap into a constant source because then the amp would be on 24/7. You need to tap into a 12V switched ignition source. The gray wire is the one you need.
Old Apr 22, 2007 | 02:17 AM
sddykstr's Avatar
Sorry, that is what I meant, something like cig lighter power or something could work too. Thanks for the correction.
Old Apr 22, 2007 | 02:46 AM
ARIZONA-TC's Avatar
alright i just finished up i tapped the gray wire it works ok but it still doesn't turn off when i turn off the power to the radio is there any wires that do that?
Old Apr 23, 2007 | 01:52 AM
NO, turning the radio off will not shut the amp off. It's not possible with the stock HU. Turning the key off turns the amp off. No need to worry about this as you won't screw anything up having it this way.
Xx AzN xX
Scion tC 1G ICE & Interior
Sep 16, 2011 05:07 AM
Ty_Max
Aug 6, 2008 11:44 AM
my08xb
Oct 29, 2007 06:23 PM
Govt_Man
20
Sep 16, 2007 03:41 AM
NYXbScion
Feb 27, 2004 08:27 AM
