Big 3 upgrade assistance need. PLS HELP!
Old Apr 24, 2007 | 06:36 PM
Italiangurl's Avatar
Default Big 3 upgrade assistance need. PLS HELP!
i got my big 3 upgrade kit from elemental design and also got D34/78 optima yellow top battery with tsunami battery topper.
im going to have my subs system installed tomorrow and i already asked quite a handful of stores that does big three before (circuit city, bestbuy, and some underdog professional audio stores) and none of them know about the big 3 upgrades.
i will need someone that can help me step by step on how to hook up the big 3 wires to my D34/78 battery with tsunami topper. i will need to have it done by tonight cus its the only time i can do it.
Old Apr 24, 2007 | 07:35 PM
nebster's Avatar
with the tsunami topper you'll want to run your big three wires on the side terminals. as far as the actual hookups go i'll be doing a DIY next weekend if you wanna wait
Old Apr 24, 2007 | 11:22 PM
Yanki01's Avatar
ill be watching this one. I plan on doing the big3 once i get my retro back and new ED system installed!
Old Apr 24, 2007 | 11:41 PM
is it ok to have the system installed first and then big three later or better to have big 3 before?
Old Apr 25, 2007 | 12:16 AM
SquallLHeart's Avatar
it won't hurt.... but i would do it before.
Old Apr 25, 2007 | 12:18 AM
nebster's Avatar
doesn't matter either way you'll just get less of the light flickering when you do it
Old May 8, 2007 | 01:20 AM
Yanki01's Avatar
is this the way it goes....
on the stock ground under the battery, can we reuse it? Just sand it down more and also add the other one on top or seperate ground for both?
Old May 8, 2007 | 05:15 AM
nebster's Avatar
separate would be better, you can probably reuse it. the whole idea is just to beef up the stock stuff with 0 gauge or 4 gauge.
Old May 8, 2007 | 12:46 PM
Yanki01's Avatar
yea ill be using 4awg with KnuKonceptz Wires.
Old May 8, 2007 | 01:37 PM
Luc1f3r's Avatar
im doing mine with 1/0 knu wire... no it doesnt matter if you do the big 3 before or after the install. if you do it after then you will notice the improvement in your stereo...
Old May 8, 2007 | 04:21 PM
Luc1f3r's Avatar
as far as using the old ground location that is fine.. as long as you still plan on replacing/ adding wire and just using the same whole... you want the ground wire to be as big if not bigger then the power wires..
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
scioninla
14
Oct 18, 2003 03:46 AM
