Front Side Marker Blackout How To!
Old Apr 27, 2007 | 12:12 AM
iheartzombies's Avatar
Default Front Side Marker Blackout How To!
What it do!? I decided to black out my side markers today, so I thought I'd make a little how to. I know it's pretty straight forward, but hey it can't hurt to have a step by step.
First, you will need:
-Some form of tinting spray, I used VHT Nite Shade.
-Rubbing alcohol.
-Painters tape.
-A towel, microfiber. You will see why.
-Gloves. Like an idiot I didn't use any and now I have paint all over my hands.
-A flat surface.
Now:
.:Step 1!
Pop out those side markers! Don't use a flathead or anything, just pull on the plastic and kinda push the fender inwards. Not too hard though.
Once the side marker is out, disconnect it from the plug. Be careful here, because the plug can fall back into the fender and be a bxtch to get out. To prevent this, take your towel, and shove it in the side marker hole against the wire.
.:Step 2!
Now that they're all out and ready, you wanna tape off what you wont be painting, just simply wrap the painting tape around the base of the plug.
Also, take out the rubbing alcohol, and put some on a napkin. Rub the plastic on the marker with it to free any dirt or oil.
.:Step 3!
I took them outside and taped them to stand upright on a table. This made it easier to paint and it also prevented the paint from running.
Once they're all set up, it's time to paint! Shake the can well, and spray about 5-6 inches away from the marker in steady strokes. I went over about four times each coat, and did three coats total.
.:Step 4!
After the last coat, check em' over and make sure nothing is wrong. I gave em' about 10 minutes to dry a little and brought them inside to let them sit for about 4 hours. They are actually still drying as I type this!
Here is the finished product!
Now, I'm dying to put these on my car, since it's white. I will post a picture with them installed most likely tomorrow, since when I get to put these on it will be dark out and my camera doesn't like dark.
Welp, that's that. I hope this helps out someone!
Now, if someone can tell me how to get those ole' rear side markers off...
Old Apr 27, 2007 | 12:15 AM
Big_Bird's Avatar
great write up man
but im confused on how u got the marker outta the fender
Old Apr 27, 2007 | 12:17 AM
Thanks!
It's just like I said, just grip it and pull. If you can't get it out like that, push in on the fender while pulling on the sidemarker.
Old Apr 27, 2007 | 12:19 AM
Big_Bird's Avatar
hmm, i may try this, thnx man
Old Apr 27, 2007 | 12:20 AM
burstaneurysm's Avatar
Pull it from the back... you want to go from back to front. I just used masking tape to keep the harness from dropping back into the fender. I did this to my SM a couple months ago. It's nice, because the side markers blend in now.
Old Apr 27, 2007 | 12:24 AM
SupaStarxAKid's Avatar
nice lil' write up!
Old Apr 27, 2007 | 12:29 AM
crubrico's Avatar
next project! now i got somthing to do on my day off!
Old Apr 27, 2007 | 12:37 AM
Thanks! It is a fun project, takes about 20 minutes tops.
Hope this writeup is good for the xA people too!
Old Apr 27, 2007 | 01:13 AM
Here they are on the ride!
Old Apr 27, 2007 | 01:21 AM
jayrod's Avatar
i like the brightness of your headlights... what bulbs (and/or new housing) do you have in?
Old Apr 27, 2007 | 01:23 AM
It is the stock housing with Silverstars. I was running luminics, but they blew my fuses.
Old Apr 28, 2007 | 12:33 PM
Blue_Batmobile's Avatar
nice .
Bat™
Old Apr 29, 2007 | 02:20 AM
Archngl's Avatar
can you see the light thru the paint?
If so, post pics!
Old Apr 29, 2007 | 03:02 AM
nnnickkk's Avatar
your car looks SLAMMED in that pic. wtfeckkkkk? hah. good write up. i was running mine smoked with vinyl for a while, now i have them painted red.
Old Apr 29, 2007 | 04:15 AM
Nice, thanks nick. I get a lot of comments about my car lookin' slammed. I am on Df210's but I have a little trick I used to get them to settle extra fast. That might be it, but I still want to go lower. Saving for some coils soon.
You can see the light, although not as good as when it was clear. It lights up orange, I will take a video of it tonight.
Old Apr 29, 2007 | 06:00 AM
Here is the vid.
Old Apr 29, 2007 | 06:20 AM
backseatchris's Avatar
Here is the vid.
looking good!
Old Apr 29, 2007 | 06:21 AM
Thanks! As you can see it's visible. Not as bright as it was when it wasn't painted, but still visible.
Old Apr 29, 2007 | 05:05 PM
nnnickkk's Avatar
how did you make the springs so low? cut or heat. im dying to go lower. PM me or aim me about it. i dont want to clutter the thread
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
Inazuma
20
Dec 14, 2003 06:09 AM
