501s + 5mm spacer?
Old Apr 27, 2007 | 06:43 PM
andizbox's Avatar
Default 501s + 5mm spacer?
i have a set of 501s on my box that im thinking of adding a 5mm spacer to.my question is, is it safe to run a 5mm spacer with out adding longer studs?i drive alot and i dont want to end up losing a wheel.just want to push the wheel out a bit to make it flush with the front wheel.will the stock tuds be long enough?
Old Apr 27, 2007 | 10:50 PM
ChampionJeep's Avatar
5 mm will be fine. Just make sure they are torqued down. Padanky on Club xB runs them without any problems. I was going to do 5 mm but decided on running 10 mm instead.
Old Apr 28, 2007 | 11:44 AM
moderngti's Avatar
3mm is fine...
5mm gets iffy.
Old Apr 28, 2007 | 12:48 PM
5 mm is perfect 10 mm is iffy
Old Apr 30, 2007 | 03:24 AM
moderngti's Avatar
Just make sure you get at least 4 full threads of engagement... 5+ is better.
Old Apr 30, 2007 | 07:47 PM
waynesoffroad's Avatar
I bought these instead- http://www.onetongarage.com/products...him/index.html This way you don't need longer studs but they are about 10mm. Took about 30 min. to install. They also have these-http://www.onetongarage.com/products...cer/index.html
Old Apr 30, 2007 | 07:52 PM
greenguyshrek's Avatar
You can even and both the spacer shims and the a 5mm spacer. that is what I and SEXB909 have. It will push your rear wheels way out. Or you can just and the otg spacer shims. and that will put both the front and rear flush.
Old May 2, 2007 | 04:35 PM
keoki's Avatar
5mm is fine 10mm is definately not!
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
reniculous1
Aug 14, 2015 03:16 PM
