OH CRAPNEED HELP
Well i found the acc fuse and it was fine. Dose any one have any other sudgestions on what i might have done and what i need to do to fix it?
in case u did not know this is what i did.
using the factory deck to run amp and subs. i slpiced in to the grey wire behind the deck to use as a amp on power source and i shorted it out ( not sure how) but now i have no power to the deck, amp and no i have no power to the power mirrors (left and right)
if any one has had this happen or any one has any sudgestion PLEASE HELP ME...
i have an 04 xb and in the manual it tells me that fuse # 14 is for the acc , gauge, wiper and ecu. all of thouse are working fine, so i am making the assumption that it is not this fuse. dose your xb have a seperat fuse for the radio? i can not locate one in the manual. or would it be that i have blowen one with in the deck?
thx man.
thx man.
Yea, mine's an '06. I'm looking at the fusebox in the car,left hand side under the steering wheel. There's no numbers, but the label on the cubby cover says that the 3rd fuse from the right in the 2nd row is for the wipers, and the far left fuse in the 3rd row is ACC.
If you blew a fuse in the deck, I would think the amp would still turn on.
thx man, i am going to try the amp again to see if it works. i was a littel miffed when this happend so i might not have been looking to closely. i will let u know what happened.
