Installed new short shifter. check it out. ****Update******
*****Update***
So i bought a shifter off ebay recently (pretty decent for $30)and installed myself. To me it still wasn't short enough. So i purchased a heavy duty pipe cutter from lowes. The pipe cutter allowed me to cut about 2-2 1/2 inches off shifter. Now its the perfect height. Shifter also came with cage bushings. I also ordered NST cable bushings but haven't received them yet. Everything feels much more precise and shorter. love it, here are some pics. BTW i chose to use a pipe cutter b/c its a much cleaner cut than using a dremel, plus there were no metal filings to pick up afterwards and it cost like $6.
also this is my first post
*****Update******
I finally installed the NST Bushings. I did it in my garage once i got home the other night. It was pretty simple. I can notice a difference while shifting now, its kind of hard to explain. But for the most part it feels alot more direct, smoother, and precise.
short shifter on left stock on right. this pic is before i cut down more.
*****Update******
Pull out the boot and turn it inside out. You'll see a ring holding the chrome outer ring of the boot. Pull out and choke up on the boot material and reinstall. It should fit a lot better without the floppy boot around your ****. Shouldn't take more than 3-4 mins. **** looks good btw, what kind is it and where'd you get it?
Is it one of those universal fit ones? Or a screw-on one?
hey guys, i got a question, maybe this was being asked before
instead of swapping the whole shifter
can i cut down the shift stick, narrow it, and make new tread for the shift ****
regardless of how difficult that might sound, do you think it'll help performance like the whole kit does?
http://cgi.ebay.com/ebaymotors/JDM-S...spagenameZWDVW
how about that one guys, is that all i need to do the swap?
i didn't wanna do it, but yours looks kool
http://cgi.ebay.com/ebaymotors/JDM-SHORT-SHIFTER-THROW-BOOT-04-05-06-07-SCION-TC_W0QQcmdZViewItemQQcategoryZ33736QQihZ019QQitemZ290108975350QQrdZ1QQsspagenameZWDVW
http://doctorisotope.com/index.php?o...d=15&Itemid=29
he does the same thing but better. and you might want to consider getting cable bushings. I cant wait to get mine
NonStopTuning
Jun 29, 2015 07:42 PM
Strader
25
Jul 22, 2004 09:27 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
