HID ballast mouting
Old Apr 30, 2007 | 05:13 PM
jay_tu's Avatar
Default HID ballast mouting
Hi All,
I searched for places to mount the HID ballasts... seems like mostly people are using double sided tape or velcro to do this...
Has anyone used the mounts for the ballast and screwed it in... if so where...
For the pass side I was thinking near the washer fluid pump... there was a " screw hole " that seemed to match perfect....just a little tight with the ballast there
For the Driver side I was thinking under the battery there are 2- 3 holes use one of those ?
I dont want to drill any holes... and not sure about using velcro or double sided tape, since there are the most worst pot holes on my way to work...
Also with velcro what are you using to hold the ballast in place
Thanks
jay
Old Apr 30, 2007 | 05:49 PM
Sleep3r's Avatar
that is what i did exactly
Old Apr 30, 2007 | 06:04 PM
jay_tu's Avatar
I guessing you mean the screws... do you have any pics of the install
Thanks
Old Apr 30, 2007 | 06:10 PM
Neothin's Avatar
get the grey 3M tape and make sure you clean the areas WELL and you'll be fine. My ballasts for my fogs have been mounted for months and are doing a-ok (the highways here in orlando SUCK)
Old Apr 30, 2007 | 06:35 PM
Sleep3r's Avatar
well i don't know if the screws provided w/ your ballast can fit in the holes but mine did do i didn't need to use 3m tape or velcro or zipties
Old Apr 30, 2007 | 06:38 PM
jay_tu's Avatar
the passenger side fits...
the driver side hold under the battery is bigger... I was thinking about getting a bigger screw from advanced.
do yo know the size for that hole by any chance....
Thanks
Old Apr 30, 2007 | 06:52 PM
Sleep3r's Avatar
actually for the drivers side, where the stock intake box use to be there are holes there i put it there
Old Apr 30, 2007 | 06:55 PM
jay_tu's Avatar
so Since I have the stock intake box... I wont be able to use those.... right ?
Old Apr 30, 2007 | 07:02 PM
leov36's Avatar
listen, if you buy 3m double sided tape from your autoparts store, no pot whole you hit will knock that ballast off, trust me. when i traded my tc in i had to rip off the ballast, that thing was attached on there so damn good, i could not imagine that hitting some bumps is going to knock it off, you could roll you car off the grand canyon and that ballast is still gonna be stuck to the car. heres a pic of the drivers side.
Old Apr 30, 2007 | 07:14 PM
niran916's Avatar
I found a spot for the passenger side. I'm still looking for a good spot on the driver side....
Old Apr 30, 2007 | 07:20 PM
jay_tu's Avatar
under the battery... ?
Old Apr 30, 2007 | 07:21 PM
SicktC06's Avatar
This guy isn't kidding....
jay_tu's Avatar
hey leov36,
is it double sided tape ? which one from here ....
http://www.partsamerica.com/ProductL...earchFor=Tapes
what did you trade the tC for ?
Old Apr 30, 2007 | 07:22 PM
jay_tu's Avatar
the highways here are pretty good... but once I get into DC the back roads suck.
Old Apr 30, 2007 | 09:34 PM
Sleep3r's Avatar
uhh yeah if you got your stock on still then i don't know. seems like you gotta 3M double sided tape it up
Old Apr 30, 2007 | 11:12 PM
leov36's Avatar
Originally Posted by jay_tu
hey leov36,
i dont think its any of those, all i know is i bought it at auto zone. its made by 3m, the actually tape itself is gray, but has one side that is covered with a red plastic layer that peels off.
traded tc for this
Old May 1, 2007 | 05:54 PM
CSOCSO's Avatar
no tape for me (dont trust in it)
on this 2 pics u can see my driver side ballast... i found a few hole behind my intake.. so on the bottom there is a short but fat screw.. and a zip tie on the top..
other side:
well i tried to find a good place but this was the easiest... i have to remove if i want to change my bulb or led... but to remove and reinstall is gonna be half minute. MAX!
so... zip tie:
ziip tied on that cable too... just to prevent too much moving..
Old May 2, 2007 | 03:56 AM
jay_tu's Avatar
i have the stock intake so i wont have access to those holes... right ?
Old May 2, 2007 | 03:43 PM
Sleep3r's Avatar
no, i did it where he did your stock intake uses those holes
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
