TakedaŽ - Momentum Sealed Stage 2 Cold Air Intake System
One of the easiest ways to get more power from your engine is to dump the OE air filter and air intake system and replace them with high-flow aftermarket parts. Aftermarket air intake systems increase airflow to your engine. This is desirable because increased airflow allows your engine to burn more fuel, and more fuel equals more power.
You can easily improve your car's performance and enhance the appearance of your engine bay with the Momentum Sealed Stage 2 Kit. Instead of placing the air filter outside the engine bay, Takeda positions a special Pro DRY S or Pro 5R air filter in a 1-piece combination air box/air scoop, where it can capture cool air forced in from the front of the vehicle. The Momentum Sealed Stage 2 Cold Air Intake Kit features an innovative 1-piece rotomolded air box/air scoop that houses the air filter and shields it from engine heat, and also takes in cool air from the front of the vehicle. The air filter is a special Pro DRY S or Pro 5R with an aerodynamic "rounded" top, to reduce air resistance and direct airflow smoothly into the intake tract. A patent pending filter-to-air box interface ensures a flawless seal.
The Momentum Sealed Stage 2 Cold Air Intake Kit comes complete with all necessary hardware, including detailed instructions. This system is backed by a 2-year limited warranty. It is available in 2 finishes - Black and Carbon.
Black Intake System with Pro 5R Air Filter
Carbon Intake System with Pro 5R Air Filter
View Air intakes on this page
Here is also an Air Flow Test, showing the difference between stock and Takeda Air Intake Kit:
Find more information about Takeda here.
What do you think about it?
VitaminE, sure. Click here to check the images of both Intakes:
http://afepower.com/catalog/TM-2013C...RF1600_400.jpg
http://afepower.com/catalog/TM-2013B...DF1600_400.jpg
Let me know if you have any other questions.
hampton1100
05-28-2015 07:32 AM
IGotThatOrangeToaster
01-19-2015 02:35 AM
