We pride ourselves on being a welcoming community we are happy to see you here and we want to get you talking to us, start here by telling us about you and your Scion.
*PLEASE DO NOT POST TECHNICAL QUESTIONS IN THIS SECTION*
rear hub removal,FAST AND EASY
Old 07-24-2016, 10:06 PM
keithmass's Avatar
Default rear hub removal,FAST AND EASY
If you would like to know how I have the answer.no heat,no removal of rear E BRAKE,its so simple...
keithmass is offline
Old 07-25-2016, 12:07 AM
Jon
Moderator
Moderator
Jon's Avatar
Welcome to the site keithmass, thanks for joining us!
Jon is offline
Old 07-25-2016, 10:11 PM
jct
jct's Avatar
i've done that too remove 4 bolts, peel away the brake assy. and remove the rear hub. simple
jct is offline
Old 08-01-2016, 11:35 PM
keithmass's Avatar
remove the 4 12mm bolts on the rear of the hub,then remove ABS connector,do not remove the rear e brake assembly,pry the ABS connector off with a screwdriver and your hub will pop off...
woodyshd
04-06-2017 06:06 PM
Suburban
12
03-31-2017 10:27 AM
SlamSandwich
07-22-2016 05:20 PM
Fury
07-17-2016 01:26 AM
carid
07-06-2016 09:52 AM
Quick Reply: rear hub removal,FAST AND EASY
