Replacing 120A fuse..
Old 12-23-2013, 08:22 PM
tcnewbie001's Avatar
Default Replacing 120A fuse..
Hi,
I am trying to replace the 120A fuse in my 2006 Scion tC. I have taken off the black plastic top and side of the fuse box to expose the beige plastic part (fuse grid?) that holds all the fuses.
The 120A fuse (see image 1, red box) is bolted into the beige plastic box on two sides (see images 2 and 3).
I have removed one bolt (see image 2) but the second is hidden behind a plastic part and a white wire (see image 4).
How can I remove the second, hidden bolt?
Images are here: tcnewbie001
Thank you in advance!
__________
tcnewbie001 is offline
Old 12-23-2013, 08:46 PM
jct
jct's Avatar
how did you blow that fuse in the first place?!
jct is offline
Old 12-23-2013, 08:49 PM
I was installing a new battery and didn't realize the one I bought had reverse posts.Any idea how to take out the second bolt after I take off the fuse box?
I can see the bolt but the plastic on the side prohibits me from taking the bolt off.
_________
Old 05-15-2019, 04:51 AM
Paulhernandez's Avatar
Default 120v fuse
An tips before I begin.
Paulhernandez is offline
Old 05-15-2019, 05:09 PM
62Fender's Avatar
You might have to remove the module from the fender well and look for screws or bolts on the underside (or any part of the module that isn't visible atm.) The module probably disassembles, exposing the screw you need to remove.
How do you know the 120A fuse is bad?
62Fender is offline
JohnA
10-28-2014 07:06 PM
Rollerskate_2004
04-11-2013 07:38 AM
Scionluber
03-04-2009 10:16 PM
J_Leon
04-29-2008 07:46 PM
TEASER
01-23-2006 09:23 PM
Quick Reply: Replacing 120A fuse..
