All Your Motor Oil Answers - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 03-17-2005, 07:58 PM   #1
LavaBox_v1's Avatar
Default All Your Motor Oil Answers
This should answer most of the oil related questions.
The company I work for in Staten Island is an ExxonMobil oil distrubtor and we also do the distrubting for Toyota's OEM Oil for NY/NJ.
TOYOTA DEALERSHIPS & OIL
Toyotas OEM Motor Oil & ATF is made ExxonMobil. ExxonMobil makes the oil to meet the Toyota Spec and packages it in Toyota packaging.
Toyota has OEM 5w30, 10w30 & ATF.
Lets start with the basics.
Toyota reccomends 5w30 on all NEW still under warranty cars ... For higher mileage they reccomend 10w30. The only different is that a 5w30 that oil will act like a 5 weight is cold weather and a 30 weight in warm weather. With a 10w30, in cold weather the oil will act like a 10 weight and in warm weather it will act like a 30 weight. There is no big difference in the oils. The 5w30 is a little thiner of an oil in cold weather but nothing that will be noticable unless you live in a climate where its below 0 all the time ... Running 10w30 in your new car is fine you wont run into problems but it is reccomend that 5w30 is used.
All Toyota dealerships buy OEM Toyota 5w30, 10w30 & ATF in Cases ... The bigger Toyota dealership have 5w30, 10w30 & ATF in bulk tanks ... Some of the smaller ones have only 5w30 or 10w30 & ATF in bulk ...
Now here is where it gets tricky ...
Not all Toyota dealerships are on the Toyota OEM BULK Motor Oil Program .. .which means if they are NOT on the program they have non-Toyota Spec 5w30, 10w30 & ATF in their bulk tanks ... If they ARE on the program they have Toyota Spec OEM 5w30, 10w30 & ATF in their bulk tanks. Toyota does NOT require each dealership to buy the OEM BULK 5w30, 10w30 & ATF but they will not warranty the engine or tranny if OEM 5w30, 10w30 & ATF is not used on cars still under warranty.
THE FIRST OIL CHANGE
For oil changes it is always best to follow Toyotas Reccomendations. You will get different answers from different people on when should do the first change should be. The only correct answer is follow what is reccomended. Some people have done the 1st oil change as soon as when they go home from the dealership and some have done it at 5k. Remember Toyota built the engine and they know best.
I am not gonna debate on which brand of oil is better or worse this is just a breif run down of the different oils and some reccomendations
CONVENTIONAL OIL
It is always reccemended to change conventional oil between 3000-5000 miles. Their is minimal anti-ware & cleaning additives in conventional oil. This oil in most cases will not hold up & protect past 3000-5000 miles.
SYNTHETIC BLEND OIL
Synthetic Blend formulas are a blend of premium conventional base fluids and a high-performance synthetic fluid. Also, these formulas offer an extra level of cleaning agents versus conventional oil. These oil changes are reccomended from 5000-7500 miles.
SYNTHETIC OIL
Yes Synthetic oil is better for your car. Yes you can go longer on oil change drains. Reccomended drains range from 7,500 miles / 6 months to 15,000 miles / 1 year depending on which oil company you go with. Yes it will help with getting better gas mileage. NO it will not fix internal engine problems. Again I am not gonna debate on which brand of synthetic oil is better or worse so I will just talk about Synthetic Oil in general. Just remember that with Synthetic oil if you are going to be extending your drains you should get a high quality oil filter that can handle the extended drains.
WHY SYNTHETICS
Conventional oils come from crude oil that is pumped from the ground. Crude oil is made up of a complex mixture of molecules that form chains and rings of different sizes and shapes. Long chains of carbon atoms produce a thick, viscous fluid that flows slowly. Shorter chains produce fluid that flows more readily.
In an oil refinery, crude oil is separated into various fractions. These become the basis for lubricating oils and fuels. Thick tangled masses of carbon chains become asphaltic materials used in roofing tar and road work. Very short chains and ring compounds of carbon are volatile and can be refined to produce gasoline and other products.
While petroleum refining is an advanced science, small amounts of contaminants, such as sulfur and reactive hydrocarbons, cannot be completely removed from petroleum, and may end up in motor oil base stocks.
All motor oils are made up of base oils and additives. In general, fully synthetic motor oils contain non-conventional, high-performance fluids. Synthetic blends usually use some non-conventional, high-performance fluids in combination with conventional oil.
To meet the demanding requirements of today's specifications Synthetic Oil uses high-performance fluids, including polyalphaolefins (PAOs), along with more additives then conventional. Each viscosity grade (5w30, 10w30, etc.) uses a unique combination of synthetic fluids and selected additives in order to tailor the viscosity grade to its specific application.
WHAT BRAND OF MOTOR OIL OUTSIDE OF TOYOTA SHOULD I USE?
If you ask what brand of motor oil to use outside of OEM Toyota you will get different answers from different people. I say use Mobil, other people say use Royal Purple, some people sale use Valvoline, some people say use Amsoil, etc. ... There is no right or wrong answer on which oil to use outside of OEM Toyota Oil. The best thing to do is so some research on each brand and see what floats your boat the most. Also you can call your Toyota dealership and ask what they reccomend for motor oil.
Here are some links to a few oil companys ... Do your own research and use what you think is best
www.mobil1.com www.exxon.com www.valvoline.com www.royalpurple.com www.amsoil.com www.shell.com www.castrol.com www.quakerstate.com www.penzoil.com
This should answer just about all of the oil questions. The best bet is to always follow what is reccomended from the factory. If you have any questions you can ask here!
LavaBox_v1 is offline   Reply With Quote
Old 03-17-2005, 08:18 PM   #2
Whocares05050's Avatar
Whocares05050 is offline   Reply With Quote
Old 03-17-2005, 08:20 PM   #3
xBino's Avatar
xBino is offline   Reply With Quote
Old 03-17-2005, 08:36 PM   #4
Scion Dynasty
Bouncer's Avatar
finally!
We needed that! Thanks!
Bouncer is offline   Reply With Quote
Old 03-17-2005, 08:41 PM   #5
LavaBox_v1's Avatar
Thanks for the praise guys! As I think of more things to add ill add them but I hit on pretty much everything Motor Oil wise ...
Old 03-17-2005, 09:23 PM   #6
KevinxB's Avatar
I've heard if you switch to synthetic its bad to go back to conventional. Is this right?
KevinxB is offline   Reply With Quote
Old 03-17-2005, 09:25 PM   #7
is that dude in the picture jerking off his nose?
240SXtoTC is offline   Reply With Quote
Old 03-17-2005, 09:26 PM   #8
LavaBox_v1's Avatar
Quote:
Its not bad to go back but if you are going to switch to synthetic is it best that you stick with it. Putting synthetic oil in your car for 1 oil change will do nothing for you. You get the full benifits of synthetic oil when you stick with it through all your oil changes!
Old 03-17-2005, 09:36 PM   #9
LavaBox_v1's Avatar
Quote:
Yes its a cartoon of Chris from the band Slipknot, he wears a mask with a long noise and he's always jerkin it!
Old 03-17-2005, 09:55 PM   #10
engifineer's Avatar
Great info! The one part that they do leave out is the fact that if you wait one year to change your oil, you will have one year of fuel vapor and condensate built up in your oil system, regardless of what kind of oil you use!!! The oil can go that long without breaking down, but you still have the engine byproducts. But.... I know people will argue... change it when you like
engifineer is offline   Reply With Quote
Old 03-17-2005, 09:59 PM   #11
LavaBox_v1's Avatar
Quote:
Each oil company is different. For instance Amsoil says 7,500 miles or 6 months on their Synthetic, Mobil says 15,000 miles or 1 year on their Extended Performance Synthetic ... It all depends on which synthetic oil you go for. I will edit that part of my post.
Old 03-17-2005, 10:01 PM   #12
KevinxB's Avatar
Thanks Lavabox.
Old 03-17-2005, 10:11 PM   #13
engifineer's Avatar
The point I was making is it doesnt matter what kind of oil you use. It will not prevent the normal engine byproducts from building up. These are part of what you are getting rid of by changing your oil. I will go longer with synthetic.... but no more than 6,000 miles. Even though the oil is still in good shape at that point, there are still buildups that need to be removed. Like I said, I dont want to start another oil change argument, but that is something that most people leave out (especially oil companys trying to sell their long life oil) when considering the time between oil changes.
Old 03-17-2005, 10:22 PM   #14
LavaBox_v1's Avatar
I understand what you are saying but Synthetic oil is made to handle thoes extra biproducts and also stop harmful build ups. Im sure mobil took into account that there will be some biproducts and would not have said 15,000 miles or 1 year if the oil would not stand up. Same thing with Amsoil they say 7,500 miles or 6 months and im sure they took into account the biproducts.
Old 03-17-2005, 10:50 PM   #15
LowProMofo's Avatar
Great info LavaBox!
LowProMofo is offline   Reply With Quote
Old 03-22-2005, 08:30 AM   #16
I love synthetic, but if you plan on using synthetic oil, plan on changing the oil yourself. If you go to an oil place like Valvoline or Jiffy Lube you will pay a ridiculous amount of money to get your oil changed. Another thing about synthetic oil is that you have to willing to spend about $40 per oil change for all of the necessary crap (i.e. performance filter, the oil itself, and a pan to catch the oil) that goes along with it.
Eski628 is offline   Reply With Quote
Old 03-22-2005, 03:25 PM   #17
LavaBox_v1's Avatar
You do not need a new pan to catch any oil ... if someone sold you an new oil pan then you need to go get your money back ... ALSO you do not need a performance filter. It is reccomended but not a requirment. Synthetic oil is expensive but you are paying for a better quality oil with better protection and more cleaning additives.
Old 03-22-2005, 11:50 PM   #18
Super Moderator
SuperMod
dgHotLava's Avatar
i don't think he meant an oil pan for the car...
but rather when changing the oil yourself, the bucket or pan you drain the oil into...
dgHotLava is offline   Reply With Quote
Old 03-23-2005, 12:12 AM   #19
Lonely_Raven's Avatar
Good info LB, thanks for sharing.
I signed up for the "Toyota Extended Auto Care" (I think
that's what it was called) where they do all the oil changes
for me for the 5 years of the auto loan. I doubt I could talk
them into synthetics, but I do love synth. Mobile 1 is what
comes in all the new Porsche, and what I've been using for
years. My SAAB (before it was hit and totaled) had 330,000
miles on it when it died! Probably would have hit 400,000
if I was careful!
Lonely_Raven is offline   Reply With Quote
Old 03-23-2005, 04:43 AM   #20
engifineer's Avatar
I have just seen some pretty sludgy looking motors from going 7500 miles like the oil company said....
Reply
Thread Thread Starter Forum Replies Last Post
Would it be better to use basic, synthetic blend or Full Synthetic motor oils? 06ScionTc5sp1 Scion tC 1G Owners Lounge 8 09-15-2015 07:46 AM
Oil around spark plug thread elwaylite Scion xB 2nd-Gen Drivetrain & Power 1 04-30-2015 03:31 PM
Not the AC Blower Motor Moth Scion xB 2nd-Gen Owners Lounge 2 04-14-2015 01:17 AM
Yet another basic replacement comoonent question kleecker Scion xB 2nd-Gen Drivetrain & Power 0 04-04-2015 03:37 PM
Motor swap 05 tc, 07 motor?? Boostedyota Scion tC 1G Drivetrain & Power 11 02-20-2015 06:38 PM
Tags
2004, 2005, buy, engine, grade, kind, motor, oem, oil, scion, synthetic, toyota, xa, xb, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
