First Oil Change
Old 05-30-2006, 05:48 AM
tc2o0's Avatar
Default First Oil Change
When should I change my oil? I have read on other forums about changing it at 500, then 1000 then 3000 then going synthetic at 10K or 12K. I can't find anything on this forum about this topic. Thanks.
tc2o0 is offline
Old 05-30-2006, 05:53 AM
OldYeller's Avatar
Read this post:
https://www.scionlife.com/forums/vie...ight=mobil+oil
OldYeller is offline
Old 05-30-2006, 05:54 AM
tc2o0's Avatar
I read that post. Nothing in it helps or has any info that I don't already know. Thanks though.
tc2o0 is offline
Old 05-30-2006, 06:00 AM
OldYeller's Avatar
I have read lots of posts and there are a lot of opinions. I have heard all of the mileages you posted being promoted. I have read that when you go to synthetic you should stay with it. I believe most people that are going to synthetic go to it on their first change.
Old 05-30-2006, 08:34 AM
Team ScionTific
2fast4you's Avatar
All you're going to find is opinion, so I'll add mine:
Switch to synthetic anytime after the 1000 mile break-in period and change at the specified intervals after that.
2fast4you is offline
Old 05-30-2006, 08:55 AM
2_tC's Avatar
Remember, you have 3 free oil changes from Scion. I used those at 2500, 5000, and 7500 miles. I just switched to synthetic at 10000 and plan to change every 5000.
2_tC is offline
Old 05-30-2006, 12:31 PM
06scionsc's Avatar
The intervals you speak of are recommended when building a new high performance engine. On a brand new engine from the factory it is recommended that you wait until 3k or 5k. It will not damage your engine in any way. I am not sure on toyota's but I know on vw's they actually use a special kind of synthetic designed to provide more wear on their motors, so th car breaks in faster. I personally change my oil every 3k with mobil1 10w-30. It's really a matter of opinion, but don't go past 5k unless you run long life oil. And in that case change the filter every 5k.
06scionsc is offline
Old 06-11-2006, 02:49 AM
PBflorida's Avatar
New cars come with a special blend of oil for the break-in period, once you get your first oilchange you may notice a change for the worse. For this reason I like to wait until 4k or 5k miles, even tho some people recommend quick oil change for new cars because the oil may acquire more engine particles.
Once you switch to synthetic stay there, don't switch back and forth. Switch early, if you switch on a higher mileage vehicle you are more likely to get oil leaks. Sythentic will keep your engine cleaner but is probably not a wise investment unless you plan to keep your car for several hundred thousand miles, if you drive like a maniac, or if you exceed the recommended oil change interval. You should still change your oil at 5000 miles tho synthetic is somewhat more forgiving if you get lazy and postpone your oil change.
PBflorida is offline
Old 06-12-2006, 10:13 AM
Music City Scions
bB2NER's Avatar
Mobil 1 after the first 1K. Then every 5K thereafter. MPG's will improve. Oh and those "free" oil changes forgettaboutit. Nothings free. You will pay something. Why risk having your car F'd up by some kid in the service dept. for a simple oil change. Not worth the risk to my baby. They can keep those suckers.
bB2NER is offline
Old 06-14-2006, 02:45 AM
tc-guy's Avatar
ur supposed to change ur oil the first time at 1000 miles because there is an additive they put in the engine from the factory that needs to be changed out after 1000 miles. after that they recommend that you change ur oil every 5000 miles. i myself still do it every 3000 miles. better safe than sorry.
tc-guy is offline
Old 06-14-2006, 04:28 AM
06scionsc's Avatar
Not sure where you got your information, but that is not true. Please read your owners manual before posting your opinion as fact. You are not "supposed" to change your oil after 1000 miles. It is not stated in the manual or by toyota. Don't believe me? Call toyota and ask. There is nothing wrong with changing you oil every 5k including your first oil change. It will not hurt your engine. You are not talking about a rebuilt or high performance engine here. This is a brand new stock motor. If what you stated was fact every dealer would tell you and the factory would include it in the manual.
Old 06-14-2006, 09:06 AM
tc-guy's Avatar
hey, im just repeating what the elk grove toyota and maita toyota service dept. told me when i asked. in any case there is no harm in changing oil too early, there is only harm when changing it too late. lastly, what is the point of forums..........it is to get other ppls OPINIONS! if u don't want other ppls .02 than don't post on here. i dunno.... just MY OPINION.
tc-guy is offline
Old 06-15-2006, 01:40 AM
Music City Scions
bB2NER's Avatar
You can do what you want with your car. If you had a clue as to what happens during break-in you would not want that oil going through your motor for 5K. As the engine breaks-in you get metal shavings because all the moving parts are mating to each other. It's a fact of engine life. Just because they tell you it's OK doesn't mean you HAVE to do it. It's cheap insurance to do it at 1K miles
The best thing is to change it at 1K and make the switch to Mobil 1. I plan on getting 300K out of my motor and have gotten 500K plus out of other motors doing this in the past.
bB2NER is offline
Old 06-15-2006, 02:56 AM
tc-guy's Avatar
amen jethro. thanks for ur post.
tc-guy is offline
Old 06-15-2006, 03:00 AM
Music City Scions
bB2NER's Avatar
No problem! It's amazing what people will tell other and what people will believe just because "The dealer says so"
bB2NER is offline
Old 06-15-2006, 03:52 AM
06scionsc's Avatar
Well jethro i realize that you believe because you are older than me you are some how superior. Unfortunately this is not the case. I am not stating what I believe to be fact because "My dealer told me so." In fact not only do I work at a toyota dealership, but I am ASE, Toyota, Honda, and Acura factory trained. I have also worked for VW and Audi. As for having a clue about break-in. If that is not enough for you maybe you should contact someone in private before assuming anything. I have rebuilt numerous motors in my life for customers and for high performance uses. Considering that my last vfehicle was a daily driven 11.7second, 450AWHP Mitsubishi Eclipse I think I may have a little more knowledge about engines than the average joe. If you want to change your oil before the recommended time that is your perogative. Did I say it would hurt the car to do so? No, I think not. However I did say that you should not state an opinion as fact. Unlike you I was able to make a statement without attacking someone.
Old 06-15-2006, 04:16 AM
Music City Scions
bB2NER's Avatar
06scionsc, Sorry you felt "attacked". That was not my intention. If you have all this knowledge why not try to educate others about NOT waiting till 5 K to get the break-in oil out. You DID make it sound like it was OK to wait on such an important item. Toyota doesn't really care as long as the car makes it out of warranty.
What I stated was FACT not just my opinion. I just wish others would stop relying on what Toyota and the dealer tells them. If you can take steps to lengthen your engines life why not do it?
bB2NER is offline
zzbear
04-19-2015 06:18 PM
voodoo2crue
03-18-2015 01:30 AM
cid_mcdp
01-05-2015 02:45 PM
scionman2003
19
02-26-2004 02:55 AM
BlueBox
22
11-07-2003 08:18 PM
Quick Reply: First Oil Change
