Need some repair advice.
Old 04-01-2015, 07:17 PM
SeT
SeT's Avatar
Default Need some repair advice.
I own a '07 Scion tC nearing 150k miles. I had my check engine light come on today. I happen to have an OBD reader so I checked it out. I'm getting misfires on cylinders 3 and 4. I do most of my own maintenance and repairs, the plugs and valve cover gasket was replaced about 15k miles ago. The valve cover gasket I replaced due to a small leak which stopped after replacement. I pulled everything apart to make sure I didn't screw up somehow, the gasket seemed to be seated fine. When I looked at the plugs, however, there was quite a bit of oil on the electrodes. Any suggestions what could cause this so I can avoid a costly visit to a mechanic?
SeT is offline
Old 04-01-2015, 07:39 PM
criminaltc's Avatar
Yep, two things cause oil on the spark plugs. Valve cover gasket and spark plug seals. Replace the seals and make sure you have the valve cover gasket good for sure.
criminaltc is offline
yupinmytC
21
11-08-2019 09:34 AM
JonnyBigBoss
09-26-2015 08:31 PM
SCGBox
09-23-2015 03:29 PM
excessads
08-19-2015 02:37 PM
5N1PE5
08-03-2015 11:25 AM
Quick Reply: Need some repair advice.
