A/C Problem
Old 07-06-2009, 04:10 PM
ih8civx's Avatar
Default A/C Problem
Checked the fuses, all good.
Light turns on for A/C when selecting it at the controls... however, the only air blowing through is the same temp as outside.
Fans work to blow air through the car, however, the "bog" you feel when turning on the a/c is not noticable. So I'm sure the fans are working inside the car, but not neccesarily in the engine bay.
What else could I check before forking out money at the stealership?
I hope its not the a/c condenser, the car only has 43000 miles on it.
ih8civx is offline
Old 07-08-2009, 05:16 PM
GQQSE13's Avatar
check and see if its outta freon (usually local shop will do that for like $10)
GQQSE13 is offline
Old 07-09-2009, 06:56 AM
ih8civx's Avatar
will do!
ih8civx is offline
Old 07-12-2009, 11:42 PM
ih8civx's Avatar
as was the case... cold air blowin again Thanks!
ih8civx is offline
Old 07-14-2009, 01:54 PM
GQQSE13's Avatar
glad to hear man; now you can stay cool this summer
GQQSE13 is offline
Old 07-16-2009, 09:30 PM
ih8civx's Avatar
lol... so it was cold. Now it just blows warm air.. not hot, but warm. ugh.
ih8civx is offline
Old 07-16-2009, 09:45 PM
SatsumaxA's Avatar
you may have a lose compressor belt??
have you cleaned your condenser coil this year??
SatsumaxA is offline
Old 07-16-2009, 09:53 PM
tc-guy's Avatar
sounds more like a leak somewhere. a large leak. if when you put freon in and it was cold then now its getting warm then the freon go bye bye due to a leak. get a leak check done.
tc-guy is offline
Old 07-16-2009, 10:03 PM
Ronin Scion
Ace83's Avatar
you can check leak yourself thats what I did.. Buy a refrigerant that contains dye and charge it to the low side port.. let the car run for few mins then use a UV flashlight to check leaks on the system.. my leak was on the condenser so i have to get it replaced
Ace83 is offline
Old 07-17-2009, 06:20 PM
SatsumaxA's Avatar
Dude, sorry to hear @ the coolant leak (started my reply at 3:15 finished at 3:45 so missed the update....
Definitly agree major leak,, most likely @ the condenser also. One of the casualties of having a lowered car, makes curbx/speed bumps/roadKill hazardous...
Get it fast due to system wide damage if you wait over 2/3 days.....
Old 08-04-2009, 07:28 AM
ih8civx's Avatar
Thanks guys, everything seems to be running better now. I can't wait till this things paid off so I can get something I don't touch.
ih8civx is offline
Old 05-06-2010, 02:43 PM
ricecooker's Avatar
did you ever get this A/C problem fixed, I am having a similar problem, only warm air blows out with mine too!
ricecooker is offline
Old 05-26-2010, 02:11 AM
danny662boy's Avatar
ya my ac sucks... i have to keep it on high with recycling, and after about 20 min or so then it begins to get cool.. not so much cold .. what would u think the problem? /fix would be?
danny662boy is offline
Old 06-10-2010, 01:31 AM
tCjosh's Avatar
^^not enough freon is in the system... take it to any shop to have them charge the system with freon and also have them add a dye to check for leaks.... mine cools after about 20-30mins like yours as well and it's due to me messing around with the low side port to add freon that i accidently removed some freon out of it! i have to take it in, hopefully monday and have them re-charge it again cause this 100+ degree weather is killin me!!
my wifes 2002 ford focus cools A LOT quicker and A LOT cooler than my 2006 tC! WHAT THE HELL?!?! LOL
tCjosh is offline
Rhymenoceros
Scion xD Drivetrain & Power
07-02-2016 10:12 PM
ShawnMcc
07-11-2015 11:07 PM
Opr8r
25
01-13-2004 07:42 PM
a330300
11-06-2003 11:47 PM
Opr8r
11-03-2003 03:34 PM
Quick Reply: A/C Problem
