Scion Tc Blower Motor (Fan) Location on car?? - Scionlife.com
Reply
Thread Tools Search this Thread
Old 01-17-2006, 09:50 PM   #1
Default Scion Tc Blower Motor (Fan) Location on car??
Ok, here's my situation..I took the car in today to get the TSB on the deflector done. What they found is that when my fan is on High, it makes a tumping noise..I always found that strange eversince i got the car. Now the dealership is saying that, Mices might have crawled into the opening of it and create a nest in there, causing the blower fan to hit the debries.
Now where is the blowerfan location, I'm gonna pickup the car tonight and tear it apart to see if there's anything in there, or if there is something else wrong with the part.
Any hints and tips would be apprecated..
BubbaNoy is offline   Reply With Quote
Old 01-17-2006, 10:23 PM   #2
hmm, i'm thinking it might be behind the glove compartment, there somewhere..we'll see what it turns out to be..
Old 01-17-2006, 10:29 PM   #3
Batjew's Avatar
just have the dealer do warranty work. if that's not a normal sound, they should be helping you out.
Batjew is offline   Reply With Quote
Old 01-17-2006, 11:29 PM   #4
well the dealer is not saying that they'll look into it at all, they want 99 dallors to open it up, and are saying that rodents have gotten into it, thats it, nothing more..
I dont know, when it comes to sales the dealership is great, but when it comes to service, they suck...so i'm just gonna open it up myself tonight or this weekend and see whats up. If after i check it out and it's still vibrating like crazy, I guess I'll just goto another dealership..Or i'll just buy the part and fix it myself. it shouldnt be too hard to fix..
Old 01-17-2006, 11:49 PM   #5
Admin Emeritus
Admin Emeritus
Tomas's Avatar
Your blower assembly is behind the 'glove box' and direcctly below the little filter drawer there. If you pull out the filter drawer and have a small inspection mirror (a mirror-on-a-stick like a dentist uses ) you should be able to look down into the squirrel-cage assembly, to see if there is something in it that shouldn't be.
Don't drop anything into the blower, don't stick fingers/mirrors/whatever in there while the blower is running.
If you need to remove the blower assembly, it turns into a whole different ballgame - in order to get it out you will be fiddling with the ECU and the passenger airbag and parts of one of the air vents to get to it... If you don't have the Service Manuals don't EVEN try it...
Good luck!
Tomas is offline   Reply With Quote
Old 01-18-2006, 12:46 AM   #6
thanks tomas
any links to a service manual somewhere, i downloaded on my other computer a while back, but now it's dead..guess i'll just have to do it blind, never stopped me before..
Old 01-18-2006, 12:54 AM   #7
Admin Emeritus
Admin Emeritus
Tomas's Avatar
Well.........
Now that you mention it, Premium Members do get full time access to the on-line Repair Manuals for the xA, xB, and tC here at ScionLife...
:D
Old 01-24-2006, 02:15 AM   #8
well, i tried it, and it was the easiest thing there is to do...
all you have to do is take off the glove compartment, remove the plastic bottom part that sheilds the glove compartment and wala..the blower motor..to remove it all i had to do was unscrew 3 screws holding the blower motor in place.. on the botom of the unit...and the motor and cage drops right out...turns out it has a peice of insinlation in the blower motor..removed it with my fingers, and wala...it's fixed..took less then 10 mins from start to finish, and no money was exchanged...
Screwed the dealership and their overprice crap!!!, I'm doing all the fixing myself from now on..
Reply
Thread Thread Starter Forum Replies Last Post
Bad motor mounts? XirtaXa Scion xA/xB 1st-Gen Drivetrain & Power 11 07-23-2016 08:11 PM
tC2: Tsudo S2 Catback russiankid PPC: Engine / Drivetrain 2 06-27-2015 12:01 AM
squeak going over bumps scotttie17522 Scion tC 1G Suspension & Handling 2 12-12-2014 04:42 PM
socal tc2 BLURMARK2 Introduction Forum 1 11-29-2014 01:12 AM
Scion coupe Risen_Son_Racing Scion tC 1G Owners Lounge 25 05-06-2005 03:31 PM
Tags
2006, blower, car, due, fan, heat, located, motor, nest, quirrel, replacement, scion, tc, toyota, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
