Service Bulletins
Service Bulletins
This is post to keep all service bulletins easy to find. when you have one, feel free to post the tsb number. If you see any false information here, please pm me or post and I will edit this post with the correct information.
cd player skipping:
TSB # AU004-03
PANT Bulletin 03-23
Rattles:
http://home.earthlink.net/~frazsj/SQ...ERVICETIPS.pdf
Cold Air Intake:
There is a problem with the cold air intake rubbing and messing up the filter. Take it to any dealer to have this fixed, although I don't know about any TSB's for this.
Thanks to CorollasBest For TSB Info
http://www.corollatoys.com/parts/ScionTSBs.htm
SCION TSB's
TSB Number Issue Date Applicable Vehicles Title
AC002-04 FEB 04 xA/xB A/C Not Cold Enough
AU004-03 AUG 03 xA/xB Single CD Player Pause
AX001-03 MAY 03 xB Initialization of Radio
AX006-03 DEC 03 xA Security Passive Arming Mode
BO020-03 NOV 03 xB Back Door Trim Loose
BR001-04 FEB 04 xA Zero Point Calibration
NV007-03 JUL 03 xA Squeak and Rattle Service Tips
NV008-03 JUL 03 xB Squeak and Rattle Service Tips
UPDATE LINK
http://www.corollatoys.com/TSB/Scion.htm
EDIT: tC TSB List:
http://home.cfl.rr.com/icdedppl/faq.html#b7
-10/14/05 - ack154 -
cd player skipping:
TSB # AU004-03
PANT Bulletin 03-23
Rattles:
Cold Air Intake:
SCION TSB's
UPDATE LINK
EDIT: tC TSB List:
Air condtioning TSB
Air conditioning blowing too warm:
TSB# AC002-04 posted feb11th 2004,
if you're having trouble just go to your dealer, they can look it up. basically you need to adjust the air-mix damper control cable assembly.
Re: Air condtioning TSB
I used my AC for the first time this week and it's not very cold.
Thanks.
sIcKsCiOnS
DelMarVa
Scion Tuners
if ne one needs TSB's emailed...email me at banditsinc@yahoo.com
i got em all, and no there is none open now for the cold air intake...ill keep checking for updates
sIcKsCiOnS
DelMarVa
Scion Tuners
im just tryin to make ur lives easier
cuz ive been in scions with these annoying rattles and wutnot, and i know how bad it is...
if not, can u send all the scion xb TSBs to accordted@yahoo.com ?
thanks so much
Found some really great websites for locating service bulletins, recalls, etc. I'm sure as the cars get older, more items on Scions will show up. Here are the links:
http://www.alldata.com/TSB/04_mk.html
http://www.autosafety.org/article.php?scid=98&did=556
http://www.nhtsa.dot.gov/cars/problems/
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
http://www.mycarstats.com/auto_TSBs/TOYOTA_TSBs.asp
http://www.theautochannel.com/F/db/s...bulletins.html
Does anybody have the actual text of the air con TSB? Can you kindly post it or point me to the location? thanks in advance
Originally Posted by icemilkcoffee
I just clicked through all those links. None of them have the xB TSB's.
Originally Posted by WS Scion
ikonXone created this topic and included this link http://www.corollatoys.com/parts/ScionTSBs.htm. Check out AC002-04 (the first one listed).
