How to wash your car properly?
All the supplies that I'll need for a proper wash
shut off valve, quick connector, hose nozzle w/ attached male connector
rinse bucket plus wash mitts softening in soap water bucket
spraying off the wheels and tires
foaming up the wheels/tires
after
rinsing everything loose off the paint
foam pre-rinse
foaming up the wash mitt
gently gliding the mitt over the paint while spraying foam at the contact point.
enjoy!
more discussion-http://autopia.org/forum/showthread.php?t=67606&page=1
You should wash your wheels LAST as they are generally the dirtiest part of the car. Getting that grime and brake dust on your wash mit before washing the rest of your car with that mit is a very bad idea, and will help cause swirls.
Originally Posted by xnevergiveinx
why would you use the same wash mitt on your paint that you use on your wheels?
yeah guys, separate mitts for the wheels. paint mitts don't ever touch them, period.
switch out your paint mitts often also. dirt gets trapped in them even after rinsing in the rinse bucket. you wouldnt really want that rubbing against your paint now would you?
Originally Posted by Neothin
I also see you have 5 mits, why so many?
What about drying towels and which ones to get?
I have an air compressor and see I could use that but do I need an special adapter?
BTW, I'm doing a lot of research on cleaning and wax today so people like you stop asking me if my car is flint mica.
Here's Mothers Detailed Guide which really helps.
http://www.mothers.com/detailguide/detailguide.html
I spray bug/tar remover on the front first so all the bugs soak up and easier to take off. You should clean the tires first since they ARE the dirtiest. You don't want to spray the tires and have crap spray over the areas you already cleaned.
TheTripleC
01-04-2015 06:46 PM
spawnconnery
12-18-2014 08:38 PM
wesley_t
12-18-2014 06:59 AM
rcflyer15
12-05-2014 05:15 PM
