Where to run power wire through?
Just wondering where you guys are running your power wire for your systems through your firewall? I have tried searching but mobile view isn't working very well so I cannot find it.
There is a rubber groundnut just below where the gas pedal is connected. There is actually a hole in it already from the inside, u just have to cut the other end (engine side) to open it up.
Go look at the install manual for the OEM Audio + system. That's how that system is installed |
Hmm, I didn't know about the hole by the gas pedal. I ended running mine through the rubber grommet behind the glove box. Upper right corner behind glove box to be exact.
I was the same way symlink I didnt want to take a chance of getting the wire caught in the clutch break or gas so I went through the passanger side
I know this is an old thread... but maybe other people may search it in the future....
I ran my power wire on the driver's side hugging the top of the piece of styrofoam just below the front pillar. Once the power wire is past the styrofoam, I dropped it down between the door hinges where the rest of the wiring for the locks, etc. enters the cab. No drilling holes. |
