Question about gear oil's
i have a 06 tc with about 54xxx miles on it,i change the gear oil to redline from OEM from reading some threads on here,it worked good for awhile then gave me issues,so i read someplace about eneos gear oil,so i decided to give it a shot,i did the swap from redline to eneos and night and day difference and still going over 6 months no issues,Now my question is i wanna try Motul Gear 300 75-90 gear oil,someone mention thats the best stuff,but will changing back and fourth between oil's have any affect on the tranny,if you properly drain everything,
like going from OEM to Redline then to Eneos then finally Motul, cause i know its not a good idea to mix oil's and some dont mix very well,so what do you gies think if i just switch and try Motul gear oil, |
ur fine, but just stick to it after this.
is it recommended that we change every 30k or different?
Originally Posted by jwallace045
(Post 3556981)
sweet i think its time for another redline change out. Pretty easy to do. i did it last time... same day i money shifted into second though and bent my valves slightly :O.
i need to change my gear oil it hasnt ever been changing i dont think and im about to hit 80k. what do you guys recommend exactly?
Originally Posted by ScikoTRDtC
(Post 3557788)
if you use eneos if your using stock |
what about this motul gear oil...are there different viscosities? if it works well for the OP i will prolly use that.
