WTB TRD Thermostat
I want to buy a TRD thermostat for TRD s/c
Official Supercharger information thread (stickied in the top of the Forced Induction (FI) forum on here)
https://www.scionlife.com/forums/sho...d.php?t=112896 Scrolling down to the parts list: Part Numbers TRD, Supercharger Compressor Housing Bracket Replacement Part PTR01-21054 TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00 TRD, Spark Plug PTR24-21055-01 TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060 TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060 TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050 TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051 TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052 TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053 TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054 TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055 TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056 TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057 TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058 TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059 TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060 TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061 TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062 TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063 TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064 TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065 TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066 TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067 TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068 TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069 TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160 TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161 TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162 TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163 TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164 TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165 TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166 TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167 TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168 TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169 TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170 Give the dealership a call. I haven't seen too many used T-stats on here for the s/c. Good luck! 8) |
You can buy any thermostat thats 70c or less. They say you can use your stock but I wouldn't. Just incase
I got a mishmoto thermostat for sale it's 60 c I used it for a week And it's working good. Let me know. Sent from my HTC Glacier using Tapatalk |
Where can I buy it and do they make generic versions?
