Scion FR-S Forced Induction Turbo and supercharger applications...
Stock Trans, Stock Engine 324whp/250tq
Old 08-11-2012, 02:21 AM
Music City Scions
rhythmnsmoke's Avatar
Default Stock Trans, Stock Engine 324whp/250tq
Video
http://youtu.be/bX8Cx47ofz8
This turbocharged FR-S build consists of:
· Dynosty Scion FR-S Subaru BRZ Single Turbo Kit with Tial GT2871R Turbocharger
· Tial MVR 44mm Wastegate and Tial Blow Off Valve
· Injector Dynamics 850cc Fuel Injectors running E85
· Haltech Platinum Sport standalone engine management
· Haltech Wideband and Haltech Advanced Boost Control System
· Dyno Tune by Hal at Dynosty
· Traklite 18" Wheels
· BC Racing Suspension
rhythmnsmoke is offline
Old 08-11-2012, 02:28 AM
Music City Scions
Old 08-11-2012, 03:28 AM
Jon
Moderator
Moderator
Jon's Avatar
I'd be happy with that.
Jon is offline
Old 08-11-2012, 04:12 PM
TheQuietThings's Avatar
Impressive, but that motor isnt going to last very long.
TheQuietThings is offline
Old 08-12-2012, 12:47 AM
athletefeet66's Avatar
What makes you say that? 9psi is pretty reasonable.
athletefeet66 is offline
Old 08-12-2012, 12:51 AM
Jon
Moderator
Moderator
Jon's Avatar
I'm assuming because the engine is already high compression. Although I think it's a little early to speculate on just how many miles you can go before you blow something up.
Jon is offline
Old 08-12-2012, 03:35 AM
I have never seen a n/a subaru motor handle more than 5 psi safely. Now add in the fact that its compression is 12.5:1 and its just a recipe for detonation.
Old 08-12-2012, 06:19 AM
ScionFred's Avatar
It's cool to see what's possible with E85 only and no concerns about engine longevity. If the engine hasn't blown up yet they need to upgrade the fuel delivery system with at least a new pump for all that E85 and there's no way the stock clutch can handle that much tq. I doubt the stock MT can either and it's a certainty that the AT can't. I wonder how beefy the rear diff is?
ScionFred is offline
Old 08-12-2012, 07:50 AM
roadrunnergt's Avatar
Pretty good. Some low comp pistons would nice
brought to you by that guy
roadrunnergt is offline
Old 08-12-2012, 07:16 PM
Music City Scions
So is the S2k, but PTuning pushes 500whp on those when they go boost. The Direct Injection from my understanding helps a lot with detonation on the FA20's.
Old 08-12-2012, 07:21 PM
Music City Scions
Fredrick Aasbo's 700hp 2jz swapped 86 was running a stock diff. After beating on it all day it finally decided to go kaput. But that's a 700hp motor swap. Don't see 250tq destroying the rear diff on this, nor the manual trans going out at this whp.
Old 08-12-2012, 07:44 PM
mmmpshh's Avatar
Thats pretty cool!
Lets blow one up before we make assumptions on what the motor can take.
mmmpshh is offline
Old 08-13-2012, 12:02 AM
Fres86's Avatar
Originally Posted by mmmpshh
Thats pretty cool!
HAHAHA! I hate to say it but I'm with you on this one!
Fres86 is offline
Old 08-13-2012, 02:01 AM
Syldrin's Avatar
have you guys seen the HKS headgasket that drops the CR from 12.6?
New product announcement from HKS… Stopper Type Head Gasket for Scion FR-S and Subaru BRZ is underway.
Two gaskets will be offered for the FA20 engine:
NA 12.6:1 Compression Ratio, 0.5mm thickness, 89.5mm bore, opposed bead type – 300HP capable (PN 23001-AT002)
BOOST 12.4:1 Compression Ratio, 0.7mm thickness, 89.5 bore, opposed bead type – 600HP capable (PN 23001-AT003)
Opposed Bead Stopper Type Metal Gasket for the FA20 engine of 86/BRZ provides higher bore sealing durability than a stock gasket. Both types are endurable against high engine output. Stopper structure of the bore seal prevents leakage even under high cylinder pressure at high engine output. Boosted gaskets compression is kept high to maintain high efficiency. Contact surface pressure is improved via a special coating applied to the head side and cylinder side to improve sealing performance when tightening the bolts.
Source: http://www.dynosty.com/tag/scion-fr-s/
Syldrin is offline
Old 08-13-2012, 02:52 PM
thendawg's Avatar
Is that 12.4 a typo? Dropping c/r by only .2 isnt going to make a damn bit of difference lol. IMHO, you at least need to get it down to the 10:1 range to safely make some decent power on pump gas. TBH though, its been talked about before with other cars, you may be able to get quite a bit of power on stock compression without too many issues if your run E85.
thendawg is offline
Old 08-14-2012, 02:32 PM
mmmpshh's Avatar
the magic juice... i dont know why boosted people are still using normal fuel. lol
mmmpshh is offline
Old 08-15-2012, 02:50 AM
Music City Scions
Because for some like me....the nearest e85 gas station is about 45min away and there is only one. I'd rather run a dual tune of 98 and MS109.
Old 08-15-2012, 03:37 AM
mmmpshh's Avatar
^ thats what 55 gallon drums are for. lol
mmmpshh is offline
eric_m
52
01-17-2019 05:50 AM
TheTripleC
01-04-2015 06:46 PM
Godfryness
01-02-2015 11:18 PM
darkshadowofxdeath
12-03-2014 06:59 PM
k1114
11-30-2014 01:40 AM
Quick Reply: Stock Trans, Stock Engine 324whp/250tq
