Turbo Stock BRZ - Scionlife.com
Scion FR-S Forced Induction Turbo and supercharger applications...
Reply
Thread Tools Search this Thread
Old 07-18-2012, 10:23 PM   #1
Music City Scions
Default Turbo Stock BRZ
Accelerated Performances car. Supposedly they were able to get rid of the torque dip in the dyno curve. They haven't posted up the dyno results yet. Still tuning.
rhythmnsmoke is offline   Reply With Quote
Old 07-18-2012, 10:36 PM   #2
Music City Scions
Old 07-19-2012, 05:02 AM   #3
roadrunnergt's Avatar
cant wait to see numbers
roadrunnergt is offline   Reply With Quote
Old 07-19-2012, 06:48 AM   #4
masterbB's Avatar
results were posted, 215hp at 4psi. thats 50hp over stock. I'm sure they will be able to improve on that just a bit with more tuning
masterbB is offline   Reply With Quote
Old 07-19-2012, 03:40 PM   #5
Should do great with 8 pounds
brought to you by that guy
Old 07-19-2012, 03:47 PM   #6
Music City Scions
Yeah 4psi and preliminary tuning. Not to shabby. Powerband dip was eliminated.
Old 07-19-2012, 04:27 PM   #7
cessblood's Avatar
They're still playing around with the fuel.
They sent some data to EcuTek.
cessblood is offline   Reply With Quote
Old 07-19-2012, 05:18 PM   #8
Music City Scions
Car still has the stock catted header in for these dyno numbers also.
Old 07-20-2012, 09:22 PM   #9
GenomeTuning's Avatar
Quote:
That is very impressive for initial tuning, cant wait to see more ecu tuning
GenomeTuning is offline   Reply With Quote
Old 07-20-2012, 09:50 PM   #10
dropzone's Avatar
Powerband dip eliminated is good news for sure. In for more vids.
dropzone is offline   Reply With Quote
Old 07-21-2012, 04:59 PM   #11
ESEMRFOZZ13's Avatar
Quote:
subaru is going to change the design, to minimize this next run. that's the pics they posted in another forum.
ESEMRFOZZ13 is offline   Reply With Quote
Old 07-27-2012, 06:57 AM   #12
ScionFred's Avatar
Quote:
Yup, after changing the pistons.
ScionFred is offline   Reply With Quote
Old 07-27-2012, 11:24 AM   #13
Music City Scions
Quote:
They are going to push it to 8lbs without pistons. Don't see any reason why it can't handle 8 either.
The S2k has a 12:1 ratio if I recall correctly. Boosting that on a stock motor and they are pushing 500whp on them. There is only one way to find out what an Fa20 will hold power wise on stock internals. 8lbs should be around the 270+whp mark I'm guessing.
If there are signs of detonation, there are still easier ways to push 8lbs without changing pistons...i.e. Methanol Injection.
Old 07-27-2012, 01:14 PM   #14
Music City Scions
4psi vs Stock
Old 07-27-2012, 03:23 PM   #15
cessblood's Avatar
Some people need to know this.
Quote:
Originally Posted by jedibow View Post
We are calculating flow, not just pressure. The more the compressor flows the less pressure required to attain a given horsepower.
We are designing the kit around a 4000 to 4500 RPM useable powerband.
Old 07-27-2012, 03:32 PM   #16
cessblood's Avatar
S2k Compression ratio is 11.0:1 but I get your point.
Old 07-27-2012, 08:40 PM   #17
The frs is direct injection along with 12:1 compression should be able to push 300hp with 8psi and a stock motor
Old 07-28-2012, 07:21 AM   #18
ScionFred's Avatar
Well my friend, there is possible and then there is practical. I'm talking reliable DD here, not a weekend racer where a blown engine is simply an opportunity to build the engine and raise the boost.
Old 07-28-2012, 07:25 AM   #19
ScionFred's Avatar
The frs is direct injection along with 12.5:1 compression might be able to push 300hp with 8psi and a stock motor
Fixed that for you.
"The more the compressor flows the less pressure required to attain a given horsepower."
That is somewhat misleading. It's the air temp that makes the difference, not the flow. The assumption here is that a higher flowing compressor will heat the air less, resulting in a denser air charge at a given pressure. Obviously there are many other variables to consider besides compressor flow and boost PSI.
Reply
Thread Thread Starter Forum Replies Last Post
tC: Stock for sale SloTC1 PPC: Engine / Drivetrain 9 04-02-2015 07:11 PM
tC: Unichip turn-key piggy back for Scion tC Turbo 9psi B_Real45 PPC: Engine / Drivetrain 1 02-23-2015 07:33 PM
low boost turbo with stock everything else spawnconnery Scion xA/xB 1st-Gen Forced Induction 1 12-18-2014 08:38 PM
2007 Turbo Tc build: Project Understated darkshadowofxdeath Scion tC 1G Owners Lounge 2 12-03-2014 06:59 PM
Scion rules out roadster, turbo versions of FR-S ScionLife Editor Scion News Forum 0 11-25-2014 03:00 PM
Tags
accelerated, block, brz, clarita, fa20, fastest, frs, hold, kit, ptuning, santa, scion, stock, tc, tuning, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
