Fuse for climate control and trac control lights
Hi everyone,
I have a 2015 FR-S base and was installing a set of Spyder fog lights this weekend and ran into a bit of an issue. I hooked the switch power wire up to the purple wire on the factory fog light plug harness. I was poking around to see which wire turned on the fog light indicator on the dash and I must have shorted the purple wire and blew a fuse. The purple wire is now dead (lost the 12v signal) and I lost the backlight on several things: dash light brightness adjuster, VSC sport and trac buttons, and climate control *****. Everything works they just don't light up, all other dash lights are on and the white wire on the fog light harness that runs the dash fog light indicator still has 12v. I couldn't find a fuse that was blown in the fuse box. Is there a hidden fuse or relay that I blew and need to replace? The manual doesnt cover these lights/fuse unless it is embeded in another fuse or relay.
Thanks for the help!
hahajoey
01-29-2023 09:51 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Beesh
01-09-2015 06:30 PM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
