Subaru86.com: Voodoo13 Suspension 2013+ FR-S and BRZ Summersale!
COUPON CODE: summersale
Visit Squarespace - Claim This Domain
Voodoo 13 Rear Lower Control Arms – 2013+ FR-S and BRZ
VooDoo13’s 2013+ FRS and BRZ Rear Lower Control Arms are designed, engineered and tested on race tracks across the globe using feedback of top tier drivers and technical directors. Precision CNC machined from high strength aluminum and coated in MIL-A-8625 Type III Hard Anodize. Heat treated Chromoly Steel rod ends and Grade 8 hardware is used to ensure they will withstand abuse from street cars and track cars alike. These control arms offer a considerable increase in strength and rigidity over the OEM stamped steel arms that are prone to flex under stress due to their thin wall construction. Three shock angle mounting and three sway bar mounting positions are available which provide you with the ultimate in suspension tuning. The mounting location to the hub is designed to allow for 18mm of drop. Camber can also be adjusted which allows the user to reduce tire wear and improve handling and stability.
We use QA1 XM Chromoly Steel rod ends that are heat treated for strength and durability. The spherical rod end is self-sealing and self-lubricated because of their Nylon/PTFE injection molded race that keeps out dirt and debris.
Includes pair of control arms and Grade 8 hardware.
Voodoo 13 Rear Toe Arms – 2013-Up Scion FRS / Subaru BRZ
Voodoo 13 adjustable rear toe arms for the Scion FRS and Subaru BRZ give you the adjustability needed to get your toe back to spec after you’ve lowered your car. Our arms are engineered and designed for high performance street and race vehicles. They replace the soft rubber OE bushing with a rigid spherical bearing for increased handling and performance, but sacrifice noise and comfort.
Our adjusting rod is made from 6061-T6 aluminum which ensures our arms are incredibly strong and lightweight. MIL-A-8625 Type III Hard Anodize finish is available in two colors Hard Clear and Hard OD Green. CNC stainless steel spacers are machined in house and work in conjunction with high quality made in the USA QA1 spherical rod ends. Grade 10.9 zinc plated hardware is included for installation.
Features:
High strength 6061-T6 aluminum adjusting rod
MIL-A-8625 Type III hard anodize finish
QA1 spherical rod ends with self-sealing and self-lubricated Nylon/PTFE injection molded race that keeps out dirt and debris
Grade 10.9 zinc plated hardware included
Features:
NonStopTuning
Scion FR-S Drivetrain & Power
14
05-05-2017 06:52 PM
Subaru86
08-02-2015 05:49 AM
Subaru86
07-31-2015 04:33 AM
