17 Inch Sparco Assetto Gara
Hey folks,
I didn't do a very good job chronicling the history of my tC, but I'm going to post everything i do to or learn about my iQ.
Just finished installing Sparco Assetto Gara (Graphite) rims with Toyo Proxes4 tires. Here are all the specs to that setup:
17x7 with 37 offset (thanks to Surfcity I know that 35-45 offset will work)
215/47/17 tires (8.4 in wide, 24.8 diameter, sidewall 3.8 inches)
With this setup the tires come all the way out to the fender. Maybe just a little beyond, but I did go with the lower offset and wider tire... A 40-42 offset with a 205/45/17 would probably be the best setup for lowering the car, but the look I have now has kind of grown on me.
I have 70mm clearance from tire to fender in the front and 90mm of clearance in the back. I'm considering the TRD springs. They give me some drop but not too much (I learned my lesson by slamming the tC - my wife used the body kit bumper as a snow plow and curb feeler for years). The TRD springs give you 1.2in/30.48mm of drop all around. So, I'll still have some clearance. I do believe that with a TRD set up a big bump/dip (or curb at full lock) will give me a little rub. Maybe?? Not sure what the camber does as the tires move up and down. If it pitches in negative at all, then I should be ok.
Wheels weights for those of you that are interested in minutiae:
Sparco - 19.8lbs
Steelies - 17.0lbs
Toyos - 22.2lbs
Stock GY - 17.0lbs
Hubcap - .4lbs
So, roughly 8lbs per tire increase.
Five days straight of rain and the tires have great wet traction. No slide parking for me.
I did add a set of Muteki lugs, but I didn't weigh them because my wife already thinks I'm ridiculous.
I've order mud guards because for this set up, but it's also occurred to me that this would be perfect for someone who's installing a widebody kit.
I have a resource to suggest for those of you doing tire/wheel research.
www.1010tires.com has a great calculator for figuring out tire dimensions.
Pics:
Sparco - 19.8lbs
Steelies - 17.0lbs
Toyos - 22.2lbs
Stock GY - 17.0lbs
Hubcap - .4lbs
Pics:
Wrong offset and tire size. The correct offset for a scion iq on an aftermarket wheel should be 45 if you want to keep your speedo proper your tire size should be 205-45-17
A 37 offset will rub if you hit a hard enough dip in the road.
My iq is on Megan coil overs I sit extremely low. I run this combo and I have zero rubbing no mater what!
Those look cool!
I guess I could have finished reading the thread before I replied. Surf City is obviously the go to guy for mods and lowering your IQ! I just gave my two cents because I know I lot more than the average tire guy! Nice pics gives me a good look at the way they fill the wheel wells too! When and if I change my wheels I might just go this wide too. Was going to stop at 205s as I don't need all that for my work car have a little "two seater" that gets 1.03 Gs on the skidpad! That is my play car!
I am a car builder, I do not have sponsors, and I only give opinions on a part that I have purchased and used myself, my opinions are blunt honest, and I only will encourage parts that I believe are safe for my use, or others.
rvascion
11-12-2020 03:23 AM
Scionxa180
07-25-2015 05:22 AM
