Flasher Relay on Sale - A must for LED Mod
Old 03-03-2010, 03:40 PM
TWP
TWP's Avatar
Default Flasher Relay on Sale - A must for LED Mod
Item: LED Flasher Module Relay
Model: CF18-08 (part# 81980-50030 066500-4650)
Function: Fix Hyper Blinker Problem while Replacing LED Signals
Application: 05+ Scion tC & 07+Toyota Camry/Solara & 08+ Toyota Tundra/Tacoma
Following are some reference on how to replace your Flasher module and how to find the right LED bulbs from our forum members.
Link to Classified Here
TWP is offline
Old 03-03-2010, 07:34 PM
Sciontistical_One's Avatar
Will this work to correct the flash rate, regardless of how many bulbs are switched to LED's? I'm looking to replace both front and rear turn signal bulbs with LED's.
Sciontistical_One is offline
Old 03-03-2010, 07:40 PM
beandip007's Avatar
Hummm. I may do this soon.
beandip007 is offline
Old 03-03-2010, 08:27 PM
TWP
TWP's Avatar
Yes 1 flaher relay is good for all 4 corners whether you have full LED or not.
Please refer to above links for more detail.
Panson
TWP
TWP is offline
Old 03-05-2010, 09:33 PM
TWP
TWP's Avatar
Bump for a must for LED Mod
TWP is offline
Old 03-05-2010, 11:48 PM
Iceman04503's Avatar
Where in the car do i find the flasher module for the tc?
Iceman04503 is offline
Old 03-08-2010, 01:46 AM
next to the fuses... behind the access panel... on the lower left portion of your dash... if your ignition is in the "on" position, turn your signal (right or left) on and you'll hear the flasher clicking...
Old 03-08-2010, 03:07 AM
Aurora's Avatar
***Warning***
Flasher Relays do disable your lights from flashing when you lock and unlock the car.
Aurora is offline
Old 03-09-2010, 02:45 AM
I kinda want this so that I don't have to solder resistors to my LED turn signal
Old 03-09-2010, 01:48 PM
TWP
TWP's Avatar
The Bad: light won't flash when you lock or unlock your car...thanks Aurora
The Good: plug-n-play, no soldering or splicing any wires. 1 relay is good for all 4 LED corners. If you decided to go back, just take out the new relay and put in the stock one.
Panson
TWP
TWP is offline
Old 03-10-2010, 02:50 PM
TWP
TWP's Avatar
Bump for a cheap & easy mod that gives you the flexibility to go LED.
TWP
TWP is offline
Old 03-12-2010, 05:00 PM
TWP
TWP's Avatar
BuMP~~ EASY WAY TO GO LED!!!
TWP is offline
Old 03-16-2010, 09:01 PM
TWP
TWP's Avatar
Bump...
Why bother soldering load resistors while go LED on corners.
Simply swap in our flasher Relay and you get a no hyper blinking after LED Mod.
If you are going back to stealership for warranty issues, just put the stock relay in and have no problems
TWP is offline
Old 03-17-2010, 01:27 AM
Aurora's Avatar
^ Relay won't void warrenty, so no worries there.
Aurora is offline
Old 03-22-2010, 05:00 AM
TWP
TWP's Avatar
Thanks for letting us know
Bump for a great way to go LED.
No more Splicing/Cutting/Wiring/Soldering. Just swap in the new realy and put you LED bulbs in.
1 Relay is good for all 4 corners of LED signals.
Sincerely,
TWP
TWP is offline
Old 03-26-2010, 06:44 AM
Aurora's Avatar
Any word yet on how to get past the flashing lights on lock and unlock deletion?
Aurora is offline
Old 05-24-2010, 05:48 PM
twpanson's Avatar
2nd version CF19 relay is available now. New relay won't delete flshing lights while locking/unlocking.
Here is the discussion from other forum
http://legacygt.com/forums/showthrea...16#post2961016
twpanson is offline
Old 06-02-2010, 03:00 PM
twpanson's Avatar
1 relay is good for 4 corners of LED.
No more cutting or splicing.
twpanson is offline
Old 06-10-2010, 08:31 AM
twpanson's Avatar
CF-19 relay will disable hyper blinker and still maintain your stock setting.
Warning flash light won't be disabled on this latest CF-19 relay.
Sincerely,
TWP
twpanson is offline
Old 06-10-2010, 08:33 AM
twpanson's Avatar
CF-19 relay will fix hyper blinker for LED mod and still maintain your stock setting.
Sincerely,
TWP
twpanson is offline
Quick Reply: Flasher Relay on Sale - A must for LED Mod
