HELP! Corroded headlight (factory) harness * PICS
I got HID's for almost 3 years.
to be honest i bought my car used and i had some problem since day one.
i used to have some kind of grounding kit and it was installed wrong so my power went out every five minutes. Of course i took my car back to the dealership on the first week and as far as i remember they changed both factory harness ( besides uninstalling the grounding kit)
or maybe they just changed my low beam bulbs. cant really recall it.
So back to the present. i got hids since and my pass side stopped working.
i checked the cables and the factory harness is corroded and the green rubber is completely destroyed. Its soft.. like a playdoll.
Not even a regular bulb will work right now. i sprayed some wd40 on them. not sure if it will help.
What can i do now?? I do have an extra harness. can i just cut the old harness off and wire a brand new plug in there?
and i know.... i should get a relay harness. Well. i will get one but right now i have to get this fixed.
fyi: im pretty sure the factory harness was cutted/spliced once. it has electrical tape on both (+ and - ) cable.
well obviously the rubber stuff was destroyed so nothing was preventing corrosion.
Btw i just fixed both harness.. It was really easy. just simple cut and solder stuff. Only problem was the lack of space. I almost took off the battery to make some room
The new harness holds tight and works great.
I was super happy when i saw the hid lighting up. So i changed both sides.
NewBox06
02-03-2015 12:36 PM
TheTripleC
01-04-2015 06:46 PM
