2az build.
Old 01-19-2015, 03:25 PM
drobins27's Avatar
Default 2az build.
I plan on using a weapon r intake manifold, p&p head 3 angle valve job, ferrea spring and retainers, bc stage 2 cams, dezod s1 turbo kit, carbon twin clutch and 9 pound flywheel, lsd, je pistons and bc connecting rods, acl bearings all around, and arp bolts all around as well, and straight pipe out the front fender, and was wondering how much powering can I get with all the mods.
drobins27 is offline
Old 01-26-2015, 04:19 AM
SloTC1's Avatar
Depends on the tune. Probably 450whp on the conservative side
SloTC1 is offline
Old 01-26-2015, 04:55 AM
drobins27's Avatar
Ok that's what I was thinking too. I'm hoping to get to 800 I'm not looking at streetablity I'm building a true race car. I'm taking this car to skip barber and scca and nhra within the next two years.
Old 01-26-2015, 01:26 PM
SloTC1's Avatar
Hopefully you can find a trans that will hold up
SloTC1 is offline
Old 01-26-2015, 02:54 PM
Music City Scions
rhythmnsmoke's Avatar
More like high 300's. Because the S1 kit is not designed to make high hp. It's designed for entry level people. And you are going to need a fuel return system to get over 400whp as well. But yea, you need to upgrade your turbo setup, cause a S1 isn't going to cut it.
rhythmnsmoke is offline
Old 01-26-2015, 03:54 PM
drobins27's Avatar
Then would changing the turbo on the s1 kit to say a garret equivalent of a 20g or greater and change the psi spring to a 30 psi do it?
Old 01-27-2015, 02:37 AM
That_Kid_Ju's Avatar
The S1 manifold is only rated to 350 hp. To go beyond that (which with what you are building will likely do it easily), you'll need a stronger manifold. You can check out the Dezod Alpha which is pretty boss. You'll also need to look into a trans and axles that'll hold the power, along with a standalone to make full use of it.
That_Kid_Ju is offline
Old 01-27-2015, 02:55 AM
drobins27's Avatar
I'm looking into.a weissman transmission like Chris rados cause I know it will handle it. I have a motec system salvaged from my last car I can use.
Old 01-31-2015, 02:10 AM
Ronin Scion
Ace83's Avatar
interesting to have a motec setup. Post up an update on that. I don't know anyone making a harness for that on the tc, i guess you would have or have someone figure out the pins
Ace83 is offline
Old 01-31-2015, 02:49 AM
drobins27's Avatar
The wiring right now is setup for a 05 Lancer ralliart. I have to find the time to rewire it to the tc. When I do. I'll give y'all the wire diagram for the motec system.
Old 02-02-2015, 02:10 PM
Scionetics
KAD
paul_dezod's Avatar
These guys are correct. Settle in at about 350whp and be done. That system was not intended to be pushed much above that.
Besides over that threshold, you really need some more mods to make that power level reliably like a return fuel system, stand alone engine management and a built short block.
paul_dezod is offline
PseudoKirby
03-28-2016 08:45 PM
PseudoKirby
07-24-2015 03:25 PM
turdbrains
217
11-17-2008 05:12 PM
Nu_ERA
147
07-04-2007 12:05 AM
toyo4life
94
07-23-2006 10:12 PM
Quick Reply: 2az build.
