SOLVED! Fresh Manual Swap Power to Car/ Fuel Pump no crank?
Old 04-29-2012, 01:43 AM
MillerRS1's Avatar
Default SOLVED! Fresh Manual Swap Power to Car/ Fuel Pump no crank?
To anyone who has done a manual swap, I have pretty much finished it I thought just did the bypass of the clutch and now my fuel pump is all I hear but no crank nothing..... any ideas what it could be? I swapped my ECU and Engine Harness ans the Key has been Immobilized by a Toyota Tech so when I plug my key in its recognized.
MillerRS1 is offline
Old 04-29-2012, 01:45 AM
MillerRS1's Avatar
only codes Im throwing is P0102
Old 04-29-2012, 03:26 AM
my06tc's Avatar
thats the maf sensor,make sure its seated properly,or clean it,or might be bad
my06tc is offline
Old 04-29-2012, 03:32 AM
MillerRS1's Avatar
yahh but wud it cause it to not even try n turn over? or crank?
Old 04-29-2012, 01:19 PM
MillerRS1's Avatar
bump anyone?
Old 04-29-2012, 03:16 PM
my06tc's Avatar
yes,i had a maf sensor go bad,and car wouldnt even turn on or crank,had to buy a new one,put it in and boom,and had the same code as you,cause the ecu has a bad reading in it,and that could cause the car not to even start...i know a few ppl that actually had similar issues
my06tc is offline
Old 04-29-2012, 03:21 PM
MillerRS1's Avatar
Just checked its not it.
Old 04-29-2012, 04:09 PM
my06tc's Avatar
are you still getting that code,how did you check it
my06tc is offline
Old 04-29-2012, 04:50 PM
MillerRS1's Avatar
unplugged it plus it shud still crank even if it was bad
Old 04-29-2012, 04:55 PM
MillerRS1's Avatar
Also its the first start to this manual swapped worked just fine before I did this so I know its something stupid. Thinking my starter is bad.
Old 04-30-2012, 11:16 PM
MillerRS1's Avatar
replugged in my auto ecu and shifter thinking it had to do with the NSS nope can take the key out when its in neutral so I bypassed that. Still thinking the starter.
Old 05-02-2012, 12:05 AM
TotalChaos's Avatar
When you say "clutch bypass" are you referring to pressing down clutch to start the car?
TotalChaos is offline
Old 05-02-2012, 03:09 AM
MillerRS1's Avatar
Yes bc I have no manual switch for the clutch like the body harness is still the auto so I had to bypass the clutch
Old 05-03-2012, 06:50 AM
sebbyxtc's Avatar
what was it?
sebbyxtc is offline
Old 05-03-2012, 02:23 PM
my06tc's Avatar
^^^^^^^^^^^^x2
my06tc is offline
Old 05-03-2012, 05:14 PM
MillerRS1's Avatar
didn't bypass the clutch right.... did it turned right over first try but died and I got told I didn't imobilize my ecu right so trying this now.
anti_virus347
04-03-2015 05:17 PM
GetSlideways
Scion xD Drivetrain & Power
03-16-2015 11:30 PM
darkshadowofxdeath
02-11-2015 05:38 PM
cid_mcdp
01-05-2015 02:45 PM
dgm458
12-07-2014 05:59 PM
Quick Reply: SOLVED! Fresh Manual Swap Power to Car/ Fuel Pump no crank?
