Blown head gasket?
Old 04-06-2012, 08:31 AM
Spicy_McHaggiz's Avatar
I'm guessing the stock HG is an MLS. Either way, ARP head studs aren't a solve all for the issue. Replace the head gasket and use new bolts, studs are overkill for this situation.
Spicy_McHaggiz is offline
Old 04-06-2012, 01:58 PM
tcrs20's Avatar
I order ptuning arp head studs and I have a new oem head gasket I got the head studs just so I don't have to go back into the engine if I need them later
tcrs20 is offline
Old 04-06-2012, 05:19 PM
thendawg's Avatar
Be sure to get the head checked and resurfaced if need be. If you reinstall a warped head with a new head gasket, itll blow the new gasket pretty quickly. Id recommend getting the block checked too if at all possible, however the block is much less likely to warp.
thendawg is offline
Old 04-06-2012, 06:38 PM
tcrs20's Avatar
My friend/mechanic just looked at them and he said that the head and block were fine... Is there anything eles I should be looking for?
tcrs20 is offline
Old 04-06-2012, 08:32 PM
sebbyxtc's Avatar
He looked at them or checked if they were within spec? You cant eyeball that.
sebbyxtc is offline
Old 04-06-2012, 08:34 PM
bdis3's Avatar
you should really take them to a machine shop to get decked.
bdis3 is offline
Old 04-06-2012, 08:45 PM
thendawg's Avatar
You cannot check them without a machinists straight edge. Most mechanics wont have one.
thendawg is offline
Old 04-06-2012, 08:54 PM
sebbyxtc's Avatar
Thats what i meant nick ^
sebbyxtc is offline
Old 04-08-2012, 07:25 AM
A good straight edge and feeler gauges will do just fine. Most heads won't warp from normal use. But if the car over heated, that's a different story.
Old 04-08-2012, 03:10 PM
tcrs20's Avatar
He just eye balled it I'll get him to check it out right but it's never overheated when I saw all the white smoke come out of my exhaust I pretty much parked it
tcrs20 is offline
Old 05-10-2012, 09:22 PM
tcrs20's Avatar
sorry for no update but my buddy knew a Toyota tech and he came over and did whatever he had to do and said everything was fine put it back together and the engine runs great but still has to much pressure in the crank and is pushing oil out my seals so i need to figure out a good way to vent this.
tcrs20 is offline
Old 05-10-2012, 09:24 PM
sebbyxtc's Avatar
Oil catch can, its blow-by.
sebbyxtc is offline
Old 05-11-2012, 02:33 AM
Oil catch cans suck, invest in an AIR OIL SEPARATOR.
Old 05-12-2012, 03:28 PM
tcrs20's Avatar
I have a weapon r catch can that I haven't put on yet.... But what I was thinking about doing is to drill Into the valve cover put a fitting on it run a line to a catch can't te just vent to the atmospher but I'm trying to get a diffrent valve cover so I'm not drilling into my original one but if I have to I have to lol
tcrs20 is offline
Old 05-13-2012, 06:29 PM
tcrs20's Avatar
And is the blow by sopose to smell like gas?
tcrs20 is offline
Old 05-15-2012, 05:38 PM
No
Old 05-16-2012, 06:47 PM
tcrs20's Avatar
Any ideas of what could cause it ..... I think napa gave me the wrong spark plugs if that has anything to do with it ... There not iridium
tcrs20 is offline
Old 05-17-2012, 09:07 AM
sebbyxtc's Avatar
stick with iridium..one step colder..gapped to about .030
and as for your problem..you should do a leak down test
sebbyxtc is offline
Old 05-18-2012, 12:29 PM
Yes for the Iridium, F*** no for one step coder. Stop giving crap advice.
Old 05-18-2012, 05:46 PM
sebbyxtc's Avatar
Dude your a douche ^^ gtfo
He said he was turbo, not stock*
sebbyxtc is offline
Quick Reply: Blown head gasket?
