Brief hesitation. Drive by Wire issue? Normal?
Old 07-28-2015, 06:44 AM
mc1114's Avatar
Default Brief hesitation. Drive by Wire issue? Normal?
I've been feeling a very brief hesitation on acceleration if I accelerate quickly, as soon as the car starts moving. The hesitation is not felt if I accelerate at a slower rate or at any other time while driving. Only as soon as the car starts to move. Feels a lot like DBW. Is the DBW system problematic on the TC? or is what Im feeling normal for quick accelerations from a stop? Doesnt seem like it as I havent felt this in the past. Im still somewhat new to these cars and still learning what their common problems are. I searched and only a handful of threads about DBW popped up. Thanks
mc1114 is offline
Old 07-30-2015, 08:24 PM
mc1114's Avatar
So the DBW system does not seem to be very problematic from what I've read. Today at a stoplight the car accelerated fine for a split second, then there was no acceleration for literally a full 2 seconds before it picked up again, so now I know there's a problem. Since this issue right now happens very rarely, I may just wait until it gets worse and hopefully it will trigger a code. If anyone has any other insight let me know
mc1114 is offline
Old 07-31-2015, 02:04 AM
sciontc_mich's Avatar
No there aren't any issues with the DBW/Throttle body from a design standpoint. The bogging down you are feeling could be a couple of things, so check yours for the following..
1- dirty/gummed up throttle body throat/plate. If that is gummed up then the DC motor won't be able to move the throttle body, and that could lead to a delay in acceleration..
2- Dirty MAF sensor.. take it out, clean it with CRC's MAF sensor cleaner (works very well, can also use this cleaner on the throttle body/plate)
3- When is the last time the spark plugs were changed? If over 100k miles, replace with NGK part 4589, laser iridium.
4- Check the transmission fluid if it's an automatic.. If the fluid is lower than max, then it won't be able to build pressure. The auto trans fluid (ATF) is also a hydraulic fluid that helps the transmission shift, which is also acceleration.. If you see an RPM flare up, then the car moves.. that's a trans issue.
Check all things, and I bet you find one of those issues.. keep us posted.
Also, I have no problems hitting the gas from a stop and it taking off immediately, and quickly I've had issues before and it was always a dirty MAF sensor or throttle body/plate/throat.
sciontc_mich is offline
Old 08-12-2015, 02:07 AM
mc1114's Avatar
The plugs are not original and I changed the ATF with OEM fluid when I purchased it. I did clean the TB and MAF (had a high idle after this but fixed it when an PCM reset). I have not felt the extended hesitation anymore but still feel a very brief one if I accelerate quickly. Dont know if this is the normal annoying hesitation typical of a DBW system or if there's something wrong with the car. I'll have to test drive the next TC that comes into the shop
mc1114 is offline
SuperXero
Scion tC 1G ICE & Interior
02-23-2020 08:17 AM
clickclickw00t
02-18-2015 08:57 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
minter66
12-15-2014 01:45 PM
TheRedBox
10-08-2003 04:25 PM
Quick Reply: Brief hesitation. Drive by Wire issue? Normal?
