Clutch hydraulics not working
Old 10-20-2014, 01:19 AM
Maroonls1z's Avatar
Default Clutch hydraulics not working
I replaced the clutch master and slave cylinders in my 2006 tc, I vacuum bled and pressure bled the line and I can't get a full pedal or even enough to compress the pressure plate to get it into gear. There is some fluid movement and the slave compresses a little but no where near full movement. I ran nearly a quart of fluid through the lines with no air coming out so I would say it's safe to say there isn't any. I don't know what to do! I've replace many masters and pressure bleeding always works so well for me
Maroonls1z is offline
Old 10-20-2014, 10:39 PM
Maroonls1z's Avatar
So I got the car back from toyota and they told me there was some kind of procedure for adjusting and setting the clutch that involves resetting the computer? Anyone ever heard of this? Makes no sense to me seeing as there is not being electronic really hooked into the hydraulics? Anyone have any explanation or idea what the procedure is for future reference? They said that all tc's and frs's have this problem
Old 10-22-2014, 01:07 AM
That_Kid_Ju's Avatar
It's BS. They probably just adjusted the clutch pedal throw rod so that it engages higher/lower than before. It's recommended anytime you change the clutch or master/slave cylinders.
That_Kid_Ju is offline
Old 10-22-2014, 08:53 AM
Maroonls1z's Avatar
I adjusted it every which way(horrible design for adj pedal height) and still couldn't get it to work. There was no air in the system I'm sure of, just not sure what else I could have done
Old 11-21-2014, 09:11 PM
DoinItWright's Avatar
This happened to a friend of mine, we finally figured it out after a day or so. There was debris ( part of a leaf ) in the brake reservoir which prevented the clutch master from drawing fluid freely. So even tho there was plenty of fluid. The clutch master still ran dry on each push unless you took a minute to fully depress it. Maybe it was something along those lines. It had gotten stuck in the feed tube. We flushed the tube and problem solved.
DoinItWright is offline
archael666
03-19-2019 11:52 PM
yhwhdesign
10
02-06-2015 05:00 AM
Xaphoon
01-17-2015 02:12 AM
JM Auto Racing
12-19-2014 06:36 PM
eric_m
79
03-17-2013 12:21 AM
Quick Reply: Clutch hydraulics not working
