Emissions/Evap error code - Scionlife.com
Reply
Thread Tools Search this Thread
Old 07-14-2011, 06:14 AM   #1
Default Emissions/Evap error code
Hi. I just bought my 2008 scion tc from a non scion dealer about 4-5 weeks ago.
but the other day i had an check engine light come on and i had it checked out at autozone. i forgot the exact code but the guy working told me i need a new gas gap.
so a few days passed and i got a new one from pep boys. a non OEM gas cap. i put it on and turned the car on. the check engine light was still on. i went back in and the pep boys guy said i need to drive at least 40 miles to have the computer recognize the new cap. so i drove 50 miles and the check engine light is still on.
another forum i read said i should try taking my gas cap off for a short time and then put it on and drive 10/15 miles. i did.
still check engine light. and even after i nearly filled the tank still had the light.
can anyone help me? someone told me with newer cars the gas cap sometimes wont work unless its OEM. and i really dont know what to do since the cars under warranty.
spookiejoshua is offline   Reply With Quote
Old 07-14-2011, 10:55 AM   #2
Unplug the cable from your negative terminal on the battery for 5 minutes and put it back on. This will reset the ECU which should then recognize the new cap hopefully and the CEL should go off. If it comes back, you have an evap leak somewhere else.
stussy1 is offline   Reply With Quote
Old 07-16-2011, 05:33 PM   #3
SandMPerformance's Avatar
unfortunately, with evap components, the warranty is only 3 years/36k miles. Stussy is correct though, you need to reset the ECM's memory so it "forgets" about the code
SandMPerformance is offline   Reply With Quote
Old 07-17-2011, 03:54 AM   #4
tweetertc's Avatar
what you should do is have the code scanned again and have it properly tested for an evap leak. autozone or "bonerzone" as i call it is programed to sell certain item to certain DTC's.. you could have a completely different problem than what the autozone guy is telling you it is...
have the code checked again and repost...
clearing the check engine light will only turn the light off for a while until the conditions are right to run the evap monitor again...
tweetertc is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
tC2: FS: Unichip w/ Flux2 Display That_Kid_Ju PPC: Interior / Electronics 0 09-30-2015 11:05 PM
Hot Import Nights - Tampa November 14th! wayneside Regional - Southeast 0 09-23-2015 11:42 AM
Hot Import Nights - Seattle October 3rd! wayneside Regional - Pacific Northwest 0 09-23-2015 11:29 AM
Tags
07, 2007, codes, diy, emissions, error, evap, fault, information, leak, list, scion, slow, tc, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
