Engine Stutter at 75+mph
2005 Scion TC
Base/Manual Trans
108,000 Miles
Symptoms: Severe Engine jerking/shuddering at 75+ mph, gets worse as speed/RPM increases. Symptom occurs under load only after reaching operating temperature.
Suspect Causes: Spark Plugs, Ignition Coils, Dirty Fuel Injectors, Fuel Filters, O2 Sensors, Clogged Catalytic Converter
Completed Steps:
Step 1: Installed K&N high flow air filter
Step 2: Replaced Clutch (Not related, it was worn out anyway)
Step 3: Cleaned MAF sensor
Step 4: Checked to ensure no loose vacuum lines
Step 5: Replaced 04 spark plugs
Step 6 Removed, cleaned, and reinstalled throttle body
Step 7: Removed, cleaned and reinstalled all fuel injectors
Step 8: Replaced both In-Tank fuel filters
To Be Completed:
Step 9: Checked resistance on both O2 sensors.
Step 10: Use IR thermometer to get inlet and outlet temp of Catalytic converter.
There was a similar thread a long time ago that pointed to the Catalytic converters as well:
https://www.scionlife.com/forums/sci...tutter-168353/
I'm hoping to do a little more testing before replacing the Catalytic converter/exhaust manifold.
Do you guys think I might be missing anything?
Base/Manual Trans
108,000 Miles
Completed Steps:
To Be Completed:
2005 Scion TC
Base/Manual Trans
108,000 Miles
Completed Steps:
To Be Completed:
Base/Manual Trans
108,000 Miles
Completed Steps:
To Be Completed:
I would suggest starting out cheap..
Since you Replaced all the plugs, make sure they are gapped correctly.. Even though they say Pre-Gapped on the box, don't trust it, it's generally off a little..
Replace the fuel filter, there should be one under the hood, make sure the battery is disconnected, and wait a good 3-5min before you start to pull the filter, it's under pressure, so make sure you wrap it in a towel before you pull it out of inline.. If you are quick, you can change it without making a mess.
I had a similar issue on my corolla, which turned out to be bad plugs and a clogged fuel filter.
I'm going to bet it's the coil packs that are causing this stutter, because if a cat is plugged, it wouldn't be stuttering, you wouldn't be able to get up to any high speed (not being able to exhaust would limit intake).
I was looking through the FSM, and could not find a resistance check on the coil packs. The only check for them I found was to remove the spark plugs from the engine and turn the engine over and make sure there is spark. There is a voltage check on the wire harness which I will check. Since I got the mutlimeter out I'll go ahead and check the resistance on the O2 sensors.
Not to send you on a wild goose chase, but also check the crank and cam position sensors. Since they control ignition timing, an issue with either can cause symptoms like that as well. The FSM has fairly simple resistance checks for them too.
looks like it might be time to take it to a knowledgeable shop that can diagnose what's going on with their diagnostic equipment. I would say a dealership but I know from personal experience that some dealerships are not that knowledgeable. (just parts replacer's) I say a good shop because you can't just keep throwing money/parts at this, it's best to get a good shop pay them to diagnose it and find out 100% what it is. The other thing is if the coil packs aren't toyota that could be the problem too. People here have replaced 02 sensors, for example, with aftermarket versions and they did not work correctly. but my thought of a good shop still stands..
**FIXED** Crankshaft position sensor was occasionally shorting out on the engine block, when i checked the resistance a few months ago, the resistance was within imits because it wasnt actively shorting out when i tested it.
Good job finding the cause! Not many people around here who actually post up with issue resolution. Thanks for the contribution!
vanlambert
08-03-2008 07:36 PM
guitarguru44
19
08-02-2008 09:44 PM
Grateful11
11
12-04-2007 04:30 AM
dumbyaisachimp
Scion tC 1G ICE & Interior
11-27-2007 04:29 PM
