midpipe shaking hitting bottom of car
Old 03-07-2010, 06:11 AM
Team Scionara
skinnayyy's Avatar
Default midpipe shaking hitting bottom of car
So before i had a 2.5 inch s-pipe my mid pipe would hit the bolt on a heat shield every once and a while. after it is installed it shakes like crazy and is constantly hitting it. Any one else have this problem? not only is it annoying i don't want to put a hole in my midpipe! if you do have this problem how did you fix it?
and the bolt that it's hittting is ground down to just the nut on it. theres no threads showing past that.
skinnayyy is offline
Old 03-07-2010, 12:53 PM
livin_in_xtc's Avatar
Mine doesnt hit the heat shield but it does rattle a little against that black support bar. I havent tried it yet but i here other people bought new poly urethane exhaust hangers to keep the exhaust more secured and to restrict its movement cuz the factory ones are just rubber. Google 12mm exhaust hanger and you should see something from Kartboy and Cobb.
livin_in_xtc is offline
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
minter66
12-15-2014 01:45 PM
Docofmind
9
10-23-2003 04:08 PM
tC_Normo
10-22-2003 07:20 PM
Quick Reply: midpipe shaking hitting bottom of car
