Loss of low end torque
Old 05-01-2015, 01:08 AM
tCSpdRacer's Avatar
Angry Loss of low end torque
Okay, this all started a couple of months ago. I have a 2009 tC manual with a K&N Typhoon Intake and GReddy Axle-back Exhaust. All installed several years ago. I have no other upgrades dealing with the engine/transmission. Okay, so my car was starting to die all the time. I figured it was just my battery being old. I had O'Reilys check out the alternator and it tested bad. I have ended up replacing the alternator, battery, and spark plugs in the past month. All while during this time my car has lost pretty much most of its low end torque and can't figure it out. Clutch engages fine...no issues there. Engine seems to be working twice as hard. It takes me 4000+ rpms just to get moving. Engine isn't making any weird/noticeable sounds. Has anyone had this problem? If so what did you do to fix it?
tCSpdRacer is offline
Old 05-01-2015, 05:10 PM
bentheswift's Avatar
Could be a lot of things... but there is no check engine light?
If you need 4k RPMs just to get the car moving, then you definitely have a problem. Hard to diagnose with just those symptoms. Has there been backfiring or overheating? I would expect a CEL for any symptom bad enough to cause that sort of problem. I would just take it to a mechanic unless you have more symptoms that you haven't listed.
bentheswift is offline
Old 05-02-2015, 03:31 PM
cmcpride's Avatar
Possible catalytic converter broken and clogged exhaust
cmcpride is offline
Old 05-02-2015, 03:33 PM
cmcpride's Avatar
Start the car warm it up and accelerate 2200rpm in park then check to see if your catalytic is getting RED .. if so clogged..you would need to replace it..
cmcpride is offline
12xb
11-07-2015 03:44 PM
bktply
12-10-2014 05:21 PM
tbblizzard
18
12-10-2003 12:22 AM
toyotaisme
13
11-14-2003 01:37 PM
Docofmind
10-25-2003 04:33 AM
Quick Reply: Loss of low end torque
