Are my brake pads worn?
Old 01-07-2015, 06:01 PM
swrdply400mrelay's Avatar
Default Are my brake pads worn?
Heard new noises from my brakes but not sure if it's the cold or if pads need changing.
Thanks!
swrdply400mrelay is offline
Old 01-07-2015, 10:09 PM
62Fender's Avatar
What did the old noises sound like?
Can't really tell from the pic. The pad appears irregularly warn but so severely that the pic angle may be deceptive.
Average driving conditions might see 60K miles between front pad changes. Highway drivers probably get more than 60k. Rickard Petty might get 30k.
Rear pads (of the same material) typically last 2 to 3 times longer than front pads.
As for the "new noise", does it sound like shuddering or metal-to-metal (like fingernails on a chalkboard?)
Totota says the minimum pad thickness is 1mm. Anything less, it's definitely time. Anything more and it's up to the driver.
62Fender is offline
Old 01-09-2015, 01:10 AM
CodeREM's Avatar
Yes you'll need new ones. I'd suggest ceramic pads . If you are doing it yourself ensure you lube the two unpainted metal parts that hold both sides of the calipers together this will ensure the calipers don't sick and cause uneven ware and tare on your brake system. Honestly when it comes to brakes if you even THINK you'll need new ones you might as well get them, it is what makes your car stop. Also you should get your routers checked pending on how many times you've changed your brake pads. you can find this info very easily on google or a legit mechanic.
https://dl-web.dropbox.com/get/rides...2KhoPFrBsQ21pQ
CodeREM is offline
gqdabien
10-08-2015 05:36 PM
Klashan
09-24-2015 12:39 PM
DannyBoy65
09-21-2015 06:23 PM
axB
09-18-2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
09-14-2015 12:39 PM
Quick Reply: Are my brake pads worn?
