Need help Remove and Replace Tc Engine - Scionlife.com
Reply
Thread Tools Search this Thread
Old 11-11-2010, 11:09 PM   #1
TRDChargedtC's Avatar
Default Need help Remove and Replace Tc Engine
im not sure if this is the right space for it.. but i need help removing my scion tc engine and replacing it.. i need someone knowledable and is in the nc area.. close to winston salem or greensboro.. i will pay.. feed.. whatever.. i just need to get this done.. anyone free this weekend to help or anytime in the near future.. lmk 336.416.9557 or pm me!!
Thanks in advance
Jarek
TRDChargedtC is offline   Reply With Quote
Old 11-11-2010, 11:22 PM   #2
1UP Crew
Crippie's Avatar
sorry i cant help, but what happend to the motor? blown?
Crippie is offline   Reply With Quote
Old 11-12-2010, 12:56 AM   #3
yes.. just a spun bearing.. not sure why? i think it was drove hard before i bought it
Old 11-12-2010, 12:57 AM   #4
but i purchased another engine so i can drive it and put the original motor in the shop for a nice build ;)
Old 11-16-2010, 01:09 AM   #5
I can walk you through taking it out there is not much to it. Just very much time consuming.
1) Take battery out
2) Jack car up and take off the front tires.
3) Separate the Lower ball joints
4) Remove both drive shafts
5) Remove Radiator and Hoses
6) Disconnect the shifter cables from the transmission
7) Take off the exhaust manifold and the S pipe.
Disconnect vacuum lines
9) Disconnect the wire harness from the ecu and pull out the boot with wires through the firewall.
10) Double check to make sure that nothing else is connected to the rest of the car such as Wires or vacuum lines etc. If so remove them. The wire harness can stay attached to the engine because they will come out with the engine.
11) Use a cherry picker and get a short chain and find points where you want to connect a bolt though the chain onto the engine.
12) Place cherry picker in front of car and attach the chain to the cherry picker. jack up the cherry picker just enough to take off the slack in the chain.
13) Remove all the motor mounts, keeping a eye on the cherry picker make sure to jack up as much as needed to prevent the motor from sliding down.
14) once all mounts are off jack engine up and out of the car.
15) ENJOY A NICE COLD BEER.
Repeat Steps for installation!
Im not responsible for any damage or injury do too following theses steps and you should use extreme care while doing this. you use these instructions at your own risk.
jar2709 is offline   Reply With Quote
Old 11-16-2010, 01:33 AM   #6
dropzone's Avatar
There are hooks that bolt to the engine to get the chain hooked on to. Last time I tried to order them the parts guy behind the counter said they were on back order, this was almost a year ago. He didn't seem like he wanted to help much. The part numbers should be posted up somewhere.
Check this link...http://www.toyodiy.com/parts/p_U_200...MGKA_1104.html
Look for the part Hanger, Engine, no. 1 and Hanger, Engine, no. 2. Take down the part numbers and order at the dealer.
dropzone is offline   Reply With Quote
Old 11-18-2010, 04:51 AM   #7
06sciontcnda704's Avatar
Good Luck at least now the blown one can get a nice build =]
06sciontcnda704 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Need help re: Tire Size tato63 Scion tC 2G Wheel & Tire 9 09-30-2015 10:55 PM
Front lip install question torranosaurus Scion xB 1st-Gen Aero & Exterior 1 01-28-2015 05:53 AM
Do I have all the steps to lowering with the following PDF's kleecker Scion xB 2nd-Gen Suspension & Handling 3 01-09-2015 03:26 PM
Check Engine Light Mystery AdmirN Scion tC 1G Owners Lounge 9 01-05-2015 11:19 PM
tC: Supercharged 06 tc auto 77k lots of aftermarket parts!! TheTripleC PPC: Vehicles 1 01-04-2015 07:46 PM
Tags
2005, 3364169557, cover, engine, lmk, me, motor, pm, remoal, removal, remove, removed, removing, scion, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
