Question about gear oil's - Scionlife.com
Reply
Thread Tools Search this Thread
Old 05-01-2010, 03:38 PM   #1
Default Question about gear oil's
i have a 06 tc with about 54xxx miles on it,i change the gear oil to redline from OEM from reading some threads on here,it worked good for awhile then gave me issues,so i read someplace about eneos gear oil,so i decided to give it a shot,i did the swap from redline to eneos and night and day difference and still going over 6 months no issues,Now my question is i wanna try Motul Gear 300 75-90 gear oil,someone mention thats the best stuff,but will changing back and fourth between oil's have any affect on the tranny,if you properly drain everything,
like going from OEM to Redline then to Eneos then finally Motul, cause i know its not a good idea to mix oil's and some dont mix very well,so what do you gies think if i just switch and try Motul gear oil,
gp1817 is offline   Reply With Quote
Old 05-01-2010, 11:16 PM   #2
ur fine, but just stick to it after this.
Supra12big is offline   Reply With Quote
Old 05-02-2010, 06:01 AM   #3
jwallace045's Avatar
is it recommended that we change every 30k or different?
jwallace045 is offline   Reply With Quote
Old 05-02-2010, 10:30 PM   #4
my06tc's Avatar
Quote:
yea but OEM gear oil didnt do a good job, at least for me going into gear's plus reverse wasnt smooth at all,thats why people change the gear oil for its much easier to get into gears,if your auto you dont have to worry about it
my06tc is offline   Reply With Quote
Old 05-03-2010, 04:35 AM   #5
sweet i think its time for another redline change out. Pretty easy to do. i did it last time... same day i money shifted into second though and bent my valves slightly :O.
Old 05-03-2010, 05:57 AM   #6
i need to change my gear oil it hasnt ever been changing i dont think and im about to hit 80k. what do you guys recommend exactly?
ScikoTRDtC is offline   Reply With Quote
Old 05-03-2010, 01:47 PM   #7
my06tc's Avatar
Quote:
i would change it,but thats only me,some change the gear oil just to get smoother shifting with less force going into gears,youll feel the difference
if you use eneos if your using stock
Old 05-03-2010, 07:21 PM   #8
what about this motul gear oil...are there different viscosities? if it works well for the OP i will prolly use that.
Reply
Thread Thread Starter Forum Replies Last Post
2012 tC steering wheel on a 06 xB bootlgr Scion xA/xB 1st-Gen ICE & Interior 1 01-26-2016 01:22 AM
Clutch and Tranny are shot Dmmcclair Scion xB 2nd-Gen Drivetrain & Power 6 08-13-2015 07:14 PM
Larger throttle body? Greg S Scion tC 1G Forced Induction 17 05-28-2015 12:46 AM
Braille battery TotalChaos Scion tC 1G Drivetrain & Power 13 02-04-2015 10:24 PM
MPG fearturtle44 Scion xB 1st-Gen Owners Lounge 15 02-13-2004 01:15 AM
Tags
06, 2006, change, eneos, gear, ny, oem, oil, recomended, recommended, rochelle, scion, tc, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
