tc valve cover?
Old 10-01-2014, 09:20 PM
omrskr's Avatar
Default tc valve cover?
one of the screws is loose on my tc valve cover and it does not tighten anymore, as a matter of fact the screw itself came off the valve along with the bolt.
does this mean the screw hole in the valve has gotten soft? if so how can I fix it? the only way I know is to stuff something in the screw hole to make it stiffer when putting the screw back in place but im not sure if thats the best aproach, any ideas?
omrskr is offline
Old 10-02-2014, 04:17 AM
That_Kid_Ju's Avatar
Which is it, the bolt or the stud with the nut? If it's not grabbing anymore, try threaded inserts. Don't think you have enough room to tap for a larger bolt.
That_Kid_Ju is offline
Old 10-02-2014, 04:12 PM
omrskr's Avatar
the stud easily pulls out with the nut screwed on from the well and it doesnt catch anymore.
what size of threaded inserts should i be looking for?
omrskr is offline
Old 10-02-2014, 04:51 PM
Most likely m6x1, but take the stud to home depot or lowe's to verify. Or if you're savy enough, just compare the thread to one of the other bolts.
Old 10-02-2014, 06:35 PM
omrskr's Avatar
will give that a try, thanks bro (Y)
omrskr is offline
MadTitan
06-16-2016 06:23 PM
Jvg2727
Scion xD Drivetrain & Power
08-24-2015 04:40 AM
Ways808
08-02-2015 08:13 PM
stenger
07-15-2015 01:03 AM
rancur3p1c
07-12-2015 07:59 PM
Quick Reply: tc valve cover?
