Transmission fluid change cost - Scionlife.com
Reply
Thread Tools Search this Thread
Old 09-25-2011, 07:08 PM   #1
Default Transmission fluid change cost
I had a Oil change recently on my 07 tc. Its a automatic. They said I need to get a transmisson fluid flush & quoted a price that was over $200 . Seriously? Thats seems crazy! They said its because of the type that it is. Is this the normal going rate or are they just scamming me??
saba is offline   Reply With Quote
Old 09-25-2011, 08:38 PM   #2
my06tc's Avatar
of course there gonna say that,thats how they make there money,but your paying for labor not the actually fluid,pretty easy to do it yourself
my06tc is offline   Reply With Quote
Old 09-27-2011, 06:17 AM   #3
PRODIGY3000's Avatar
Sounds about right. How many miles on your stock fluid? And although I always say this, I keep saying it. This is a very easy do-it-yourself job. If you take a crack at it, it'll save you the $$$.
Some good reading on different fluid types here:
http://www.bobistheoilguy.com/forums...1080126&page=2
And a DIY for an auto:
Transmission Flush (Automatic, Eneos ATF)
btw: you should've put this in the engine/drivetrain section
PRODIGY3000 is offline   Reply With Quote
Old 09-27-2011, 06:43 PM   #4
JIMXB's Avatar
Quote:
For the Scion Xb 1st Gen, we require special Trans Fluid as I was told by a Aamco transmission place, which they do not carry + was advise to go to the Dealer to get the correct fluid. 99.9 % of the Auto parts stores do not carry the special trans fluid for our cars.
At a NJ Scion dealer, they charge me couple of year ago $70 for a Trans fluid change, which is basically a drain + refill of new fluid.
My wife got a trans fluid change for her xA at one of those quick oil lube place. Which I had to get flushed out, cause they used a generic equivelant fluid, which to me is a big No..... I asked the guy how is they have the fluid + Aamco doesn't even carry it nor would they recommed to put in a synthetic . So I went to the dealer to correct this problem with a Trans flush.
The Trans fluid flush was about $200 at a dealer. Reason they use 2x or 3x the amount of Trans fluid with a machine to totally flush your system to ensure all old trans fluid has been drained + to ensure non contamination your new trans fluid.
Good Luck + make sure you get the proper fluid for your car.
JIMXB is offline   Reply With Quote
Old 09-28-2011, 01:48 AM   #5
just diy, crazy how much money something that probably take an hour cost
1E0_Tc_05 is offline   Reply With Quote
Old 09-28-2011, 02:16 AM   #6
I have about 71,000. I bought car 2 years ago. They made it sound like it was so expensive due to a different process that had to be done for some reason. I have had a flush on other cars I have had & didnt like it since it would leak after due to the flush pressure. Doing it myself would definitely be a more cost effective route.
Old 09-28-2011, 10:30 PM   #7
amazon.com has toyota oem type IV transmission fluid. when its in stock on amazon's website, it's under $5 each and has free supersaver shipping for orders over $25. you need about 8 quarts anyway so you can do the flush yourself for about $40
bionictony is offline   Reply With Quote
Old 09-29-2011, 06:15 PM   #8
wlfpck's Avatar
The 2007 scion tC automatic transmission fluid is Toyota WS.... NOT Toyota IV.
The main difference is the viscosity. The Toyota WS (world standard is what I believe is what it stands for) is thinner than Toyota IV. The only fluid right now that you can use other than Toyota WS would be amsoil.
wlfpck is offline   Reply With Quote
Old 09-29-2011, 06:26 PM   #9
sorry about the mistake! Toyota IV is non synthetic and i believe Toyota WS is synthetic
Old 10-01-2011, 11:58 AM   #10
mrexotica's Avatar
If the dealers charge too much,
What is a fair labor charge?
I'm all for doing the simple stuff myself, but the dealer is NOT evil.
(at least if you take the time to find a dealer you trust)
mrexotica is offline   Reply With Quote
Old 10-05-2011, 04:58 PM   #11
I just got my oil changed. i asked how much the tranny fluid flush was >$125.00
tcseacliff is offline   Reply With Quote
Old 10-05-2011, 06:07 PM   #12
when i did it on the 05, it used type T-IV. i drained 3.5 quarts out. i put in 4 quarts through the dipstick tube, unplugged the line going into the transmission from the radiator cooler. i turned the car on and as it came out i poured more in. i shifted through the gears too. i used about 8 quarts. 8x$5=$40 for the fluid. WS costs about $8 a quart.
Reply
Thread Thread Starter Forum Replies Last Post
2012 Xb P0741 error code? 12xb Scion xB 2nd-Gen Drivetrain & Power 2 11-07-2015 03:44 PM
Fluid changes needed for 100+ miles kleecker Scion xB 2nd-Gen Owners Lounge 0 03-17-2015 12:15 PM
HELP! Selling STOCK 2007 tC as a 'fixer upper' and wondering if/what repairs to make mischadoll Maintenance & Car Care 3 03-09-2015 05:48 AM
coolant petcock, engine block location? mrsocks Scion xA/xB 1st-Gen Drivetrain & Power 2 01-20-2015 01:29 PM
Where is tranny drain plug? ghasper Maintenance & Car Care 8 02-22-2006 12:18 AM
Tags
2005, atf, automatic, change, cost, dealership, diy, fluid, flush, price, scion, sxion, tc, transmission, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
